front coil springs touching ibeams.
i installed a pair of aim 3" lowered ibeams, and the springs are touching the beams. ive had these beams for over 13 years on my 87 and never had a problem with them. but when i installed them on my 94 the spring hits. has anyone had this problem? here is a pic. ive been doing some reading over on the lightning board, and those guys say these trucks like to crack the middle crossmember and ibeam mounts.
when i put the truck together,i replaced:
radius arm bushings, ball joints, brake pads and rotors
the ibeam pivot bushings are urethane and are in perfect condition.
the radius arm brackets had some damage from rust and were blasted and repaired. everything on the front end was blasted and epoxy painted before re-install.
on
onlytheclouds
31
07-24-2017 04:59 AM
79Ford4x4
04-03-2010 02:24 PM
jjf2468
04-02-2005 05:17 PM
