Battery Tender vs Battery Minder
I have a 2001 F250 SuperDuty 7.3 PowerStroke. I recently replaced my two batteries as they had died due to lack of use. Other than when I take off on RV 5th Wheel trips my F250 sits. I do go out and start but forgot to the last 4 weeks, thus them having to be re charged in order to get going.
Someone told me about either a Battery Minder or Tender but not sure.
1. By having two batteries on my truck do I need a Minder or Tender for each battery or will connecting to one be sufficient.
2. Can someone recommend one to me that they have had good experience with.
3. Can you leave it hooked up all the time or do you have to disconnect when you go to crank up.
I appreciate any guidance anyone can provide.
I can only offer that the battery tenders come with a set of connectors that you can hard wire to your battery and a set of clamps you can use also.
Both these options plug into the wiring from the battery tender unit via 2 wire connector.
I have a 2 battery unit connected to my boat now awaiting spring.Smaller versions on quads n motorcycle
In fact that's what I always recommend. Check with both the battery's maker and the chargers to insure they're compatible.
If you get the style that mounts to the vehicle I recommend ensuring a safe location to make sure it will stay safe and operational. I'm a little ocd so I always put a meter on them time to time to make sure they're working.
Received 3,090 Likes
on
After reading your post I started researching the two you mentioned -
The BatteryMINDer - 12v Battery Charger, Battery Desulfator, Battery Maintainer, Charger
and
The BatteryTENDER - Home page - Batterytender.com
Interesting read - http://batteryminders.com/forms/mast...aintainers.pdf
and - Batteryminders Specials | BatteryMinders.com
Since we have two batteries run in parallel I think I'm going to go with the BatteryMINDer 2012.
Use it initially to de-sulfate each battery individually, then hook it up normally to maintain them.
$90, free shipping, no tax, a free gift (multimeter or batt tester) and automatic warranty registration. Sounds good to me.
We use the small $20 battery tender Jr. on a lot of diesel equipment with dual batteries, only hook it to one and leave them plugged in all winter. They have all paid for themselves by saving the batteries, used to replace them every few years from running down each winter.
Can be found on sale at stores for $20 or less at times:
I'm a battery minder guy!
I've been using them since the 90s.....Northern too has 'em on-sale right now for $29 (normally retails for $49, but rarely priced at that).
I back into the driveway...as a habit but I also hate cords running all over the place....
I run the cord under the garage door or thru a gap...
I never have to worry about running over a cord this way.....and If I forget to unplug - the ends just pull apart (no harm no foul)...
I have been maintaining the battery on my collector vehicle (a 1962 Oldsmobile Dynamic 88 Conv, which by the way is for sale - SEE online at 62Olds [index.html]) for well over 10 years without incident. Stays on whenever the car is in the garage.
My maintainer of choice is the Battery Tender Plus. Price is right, has a decent warranty and gets the job done!
both are similar. tender or minder...... the "JR" is not for a large battery .. and NOT for 2 batteries..
I am a battery tender Brand.guy over 10 years now.. I own 4 of them... the JR is for the electric start generator....
by the way.. the smart chip inside both are NOT made by ether company..
I have a prototype breadboard of that design chip from 1995.....
FSJ-EARL
07-29-2012 12:55 PM
Waynenap
34
04-19-2011 10:40 AM
sum_weirdo
Electrical Systems/Wiring
01-06-2008 06:10 PM
