AOD Not downshifting
As far as I know, the TV cable (I think that's what it's called) needs to be properly adjusted so the AOD work properly. I've heard you can ruin it by driving it with the cable misadjusted.
I have a C4 with the same symptom you described. I think mine has a bad governor...
Check these links out, maybe they will help you with the cable adjustments...
http://www.tciauto.com/instructions/431000_inst.htm
http://www.baumannengineering.com/tvlnkage.htm
I also saw this in a webpage:
"How do I set the TV cable and what does it do?
The TV cable on modern transmissions sets the fluid pressure to correspond with the throttle position. You can never operate a transmission designed for a TV cable without one. The fluid pressure would be so low you would burn up the bands and clutches at once. Early automatic transmissions used a vacuum modulator to set fluid pressure. The latest transmissions use the vehicle's computer to set the fluid pressure as well as shift points. If you are having problems adjusting your TV cable call Art Carr and the knowledgeable sales professionals can help you. "
Hope this helps,
Lobo
Hope this helps,
Lobo
gov2mod
13
06-29-2011 09:26 AM
tired51
03-20-2011 10:07 PM
88f150302
05-20-2010 01:54 AM
kameronth
12-25-2004 02:57 PM
glenn prentice
11-19-2004 03:45 PM
