how many spline in the Dana 44? 19?
My truck is not where I can check but my notes say the axles are 19 spline and the yoke is ten spline, ah i am the least qualified guy around so maybe get a second opinion. This is something I'm planning I have 53 f-100 with ford-o-matic running stock 3.92 gears and I want to drop to 3.55. here is my note...
(The 3.92&up ratio case has a different offset ring gear seat than the 3.73&down ratio case, if you do not want to buy a new case, you will need to find a used 3.07-3.73 Dana 44 case for use with 19 spline case)
A new aftermarket limited-slip carrier with proper offset for 3.08-3.73 gear ratios:
http://www.accuautoparts.com/axledetail ... AUB:542085
I double checked Welcome To ACCU Auto Parts
and they say...
Axle & Gears Info
Selected Vehicle: 1953 FORD F100 PICKUP 239 2WD
Most Common Axles For Your Vehicle:
REAR - DANA 44 - 19 SPLINE AXLES
good luck,
Bill
and they say...
Axle & Gears Info
good luck,
Bill
Same here Bill. It sounds like we have about the same truck. I have 3.92 gears along with the fordomatic and the 239 flathead. Everything is basically stock. I am going with 3.08 gears because I want a nice cruiser that gets decent fuel mileage. I keep you posted.
You'll also need new spider gears to go with the new carrier. Who did you order from? Only a couple of places sell 19-spline spiders that work in the newer carriers.
gsiamrod
05-12-2009 12:47 PM
lrh2phish
02-28-2008 01:13 AM
51dueller
06-12-2003 05:15 PM
elliott
03-07-2003 07:37 AM
