1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2004 16" Rims on 2008 F250
Old 01-02-2013, 12:41 PM
NobleX13's Avatar
NobleX13
NobleX13 is offline
A local craigslist seller has a set of lariat rims off of a 2004 F250. Will these fit on my 2008? I know the bolt pattern is the same but don't know about the offset.
Thanks!
Old 01-02-2013, 12:57 PM
Sparky04SD's Avatar
Sparky04SD
Sparky04SD is offline
I'm told that the 16's won't clear the brake calipers without wheel spacers. The main reason Ford went to 17's in 2005.
Old 01-02-2013, 01:46 PM
truckfella's Avatar
truckfella
truckfella is offline
So going the other way would be a-okay then, right?
(17s from 2005+ onto pre-2005)
Old 01-02-2013, 02:37 PM
Sparky04SD's Avatar
Sparky04SD
Yes, they will bolt on but wheel offset could be a problem. It's possible the wheel would stick farther out and flares required to cover tire.
Old 01-02-2013, 03:00 PM
acf6's Avatar
acf6
acf6 is offline
16" wheels will not fit on anything newer than 2004 due to larger brakes on 05+.
2005+ wheels will bolt up to 1999-2004, but the backspacing will have it hitting your leafs with barely any turning, so it will require spacers, which are $640 for 4
Old 01-02-2013, 03:11 PM
truckfella's Avatar
truckfella
Very good info. Thanks.
Old 01-02-2013, 06:57 PM
Denola's Avatar
Denola
Denola is offline
Regardless of changing wheels to other 17" , 18" or 20", don't forget the 2008 has TPMS or you'll have a new set of problems
JacobD
01-11-2018 06:07 PM
jcp8587
03-17-2016 09:36 PM
73100
11-26-2015 07:14 PM
icyford
04-15-2004 08:48 PM
Quick Reply: 2004 16" Rims on 2008 F250
