Oklahoma Chapter Join Chapter, Leader:
S.O.S. Tulsa Metro Broken Arrow OK Area
Old 01-15-2013, 12:17 AM
GamerGirlAlice's Avatar
GamerGirlAlice
GamerGirlAlice is offline
i was sending a s.o.s. to see if a nearby member can help me diagnose what happened to cause my 1971 f250 with a 360 to stop running?
Thanks in Advance, Alice
Old 01-15-2013, 06:59 AM
Gary Lewis's Avatar
Gary Lewis
Gary Lewis is offline
Posting Legend
Can you describe what happened? What were the conditions and symptoms?
Old 01-15-2013, 10:35 AM
GamerGirlAlice
well i bought it on the 9th and drove home fine & later i went n bought burgers and $25 of 87 octane fuel. on the 10th was cold and rainy but started fine, drove 1/2 a mile and it died at a traffic light. i see it pumping gas in carb, i replaced the plugs, wires, points, condenser, and coil. it already had a new cap and roater. but i just haven't been able to get it to start but it cranks hard and when it was running it had tones power and torc.
Alice
Old 01-15-2013, 02:40 PM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
Have you checked for spark? The shot of the engine brought back memories for me of my '72 w/a 390 that died at a rest stop in AZ in '72. The coil just decided it was done.
So, plug a plug wire and hold it near the engine, probably with gloves, and have someone crank it. Or, put an old plug in the wire and put the plug against the block. You should have a white or blue spark. Obviously no spark is bad, and yellow or red is a problem but the engine should start anyway.
I think it must be ignition if it was running and died. So either you lost power to the ignition itself or something like coil, points, or wiring died. If you've replaced points since it died that might be a place to look if you don't have spark. Check to see that you have power to the coil, both when cranking (12v) and when in Run (~6v) And the points should take the other side of the coil to ground when they close.
Old 01-15-2013, 10:38 PM
GamerGirlAlice
i haven't checked spark since i got new coil. i have a mechanic coming tomorrow to help me with it. said would cost $25-$30 to diagnose my problem. so i am hoping my $125 can fix the problem.
Old 01-16-2013, 12:31 AM
GamerGirlAlice
i wanted to mention i found the mechanic via craigslist with a ad here: Need Cheep Mechanic for 1971 Ford F250 Work
Old 01-16-2013, 07:53 AM
MikeB 88's Avatar
MikeB 88
MikeB 88 is offline
Just out of curiosity, did you get the new points set right?
Maybe someone here in the group who lives in BA, can check out your truck instead of a stranger on craigslist.
Old 01-16-2013, 08:25 AM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
Mike - That's one of my worries, that enough parts have been changed that there may be multiple problems, the one that caused the problem and those introduced later.
Alice - If it didn't start after installing the new coil it might still have been the coil as there now might be another problem. Hopefully your mechanic will be able to quickly diagnose the problem and you can then fix it.
Old 01-16-2013, 09:35 AM
MikeB 88's Avatar
MikeB 88
MikeB 88 is offline
I remember many, many years ago a friend of mine Mustang quit running after a rain. Turned out that water had gotten into the distributor. We took the cap off, dried it out and it ran fine afterwards. Not sure how the water got in it though.
I'm thinking that Alice's problem is very similar, since everything was changed and something isn't set/adjusted right. It sounds like her truck was running fine until the rain came.
Alice, once you get it running again you may want to upgrade the point/condenser to a pertronix system. I did that with my Thunderbird, and never looked back.
Old 01-16-2013, 09:55 AM
GamerGirlAlice
Yeah I don't know if I get the points it raining or not. But um yeah I've put so many parts into this said I'm kind of out of ideas. I really don't know if I miss gap points or if it's a bad coil or said something else going on. So I hope the mechanic can figure this out for me.
He's only charging me 25 to 30 dollars to undo the diagnostic. So that's not a bad price for diagnostic in yet. So I hope 125 total will be able to fix it. Because that's all I have left.
Old 01-16-2013, 12:44 PM
GamerGirlAlice
it cost me $20 to have it diagnosed and hes out grting parts. but what hapenend is the truck jumped timing
Old 01-16-2013, 01:03 PM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
So, he's going to pull the timing cover and replace the chain and sprockets? Hope so.
Old 01-16-2013, 01:14 PM
GamerGirlAlice
Yeah he's doing a forum timing chain gear is gaskets and all that so that will be good.
Old 01-16-2013, 01:29 PM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
Good. That would give you basically the same symptoms - fuel and fire but no run, although sometimes they'll backfire a bit. Anyway, good luck. let us know how it goes.
Old 01-16-2013, 07:53 PM
GamerGirlAlice
turns out when i bought it had no coolant in it and i over heated it. it welded the rings to the pistons. so i need a new 360 now :P
god i feel dumb for assuming coolant in the engine.
Alice
Quick Reply: S.O.S. Tulsa Metro Broken Arrow OK Area
