Reverse lights problem - Ford Truck Enthusiasts Forums
Old 01-02-2013, 11:07 AM
Daves94vert Daves94vert is offline
Daves94vert is starting off with a positive reputation.
My lights don't come on when I put the truck in reverse. I have to hit the right "spot" on the column gear selector for them to come on. Meaning, the truck will be in reverse with no lights on. If I jiggle the gear selector they'll sometimes come on. I failed my inspection but have one month to fix this problem. Is there a switch or something I can change out? The reverse lights do work, so there is no fuse broken or anything. 351W/C6 F-250. Thanks guys.
Old 01-02-2013, 12:21 PM
Dorsai's Avatar
Dorsai Dorsai is offline
Dorsai has a good reputation on FTE.Dorsai has a good reputation on FTE.
Quote:
You didn't say what year your truck is, but the switch is almost certainly on the side of your transmission, where the shift linkage comes in. See this thread for more information: http://www.ford-trucks.com/forums/11...l#post11749087
I changed my switch out last year, and other than having a terrible time with the electrical connector, it was a piece of cake. I was able to source a NOS switch from Green Sales.
Old 01-02-2013, 12:29 PM
Sorry. It's an 86
Old 01-02-2013, 12:39 PM
GLR's Avatar
GLR GLR is offline
GLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputation
Ditto on the switch. You might try adjusting it first. But, odds are a new one is needed. Not to hard to change out, Was on the side of my 86 F250 C-6 trans.
Old 01-02-2013, 01:04 PM
Is this what I need to mess with?
Old 01-02-2013, 02:21 PM
Dorsai's Avatar
That's it all right.
Old 01-05-2013, 12:43 PM
HoboBen HoboBen is offline
HoboBen is starting off with a positive reputation.
I just replaced this 2 days ago. 3 bolts. The hardest part was removing cable housing. part about 30 dollars. When replacing, put truck in neutral. You will need to put a drill bit end (not sure which one, I used a dart, prob not best tool), to line up the three holes.
FYI, I had exact same back up light issue, and they now work great.
Old 01-05-2013, 10:26 PM
madpogue madpogue is offline
madpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to behold
Actually, if the lights do come on when you nudge the shifter close to reverse, it sounds like it's just out of adjustment.
GEAR SELECTOR crazymut 1999 - 2003 7.3L Power Stroke Diesel 18 08-10-2015 02:29 PM
Reverse lights only come on between park and reverse grande1972 Ranger & B-Series 7 03-17-2013 06:21 AM
REVERSE LAMP PROBLEM skooch 1999 to 2016 Super Duty 0 02-23-2013 04:01 PM
Reverse camera delay cabindoc 6.7L Power Stroke Diesel 7 04-11-2011 06:29 AM
reverse lights not working Steve Shulz 1987 - 1996 F150 & Larger F-Series Trucks 3 06-29-2003 09:35 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
