Torsion bar adjuster removal - '99 Expy - Ford Truck Enthusiasts Forums
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator
Old 01-02-2013, 11:19 AM
TX76F250 TX76F250 is offline
TX76F250 is starting off with a positive reputation.
'99 Expy, 153K miles, AWD.
Need to remove the transfer case as it is stuck in 4WD.
The issue is getting the torsion bar adjuster nut off. The instructions say to use a Ford specialty tool, 204-185 and 204-203 to push the torsion bar adjusting bracket up and out of the way to remove the nut and blah, blah, blah. No local auto parts store has these tools to "loan" and the best price I can find on it is $149.
Is there a shadetree work around? I really need to get this done....the old lady is up my a$$ about getting her rig back on the road.
Old 01-02-2013, 05:16 PM
alloro alloro is offline
alloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to behold
Some people have done the job using a C-clamp instead of the specialty tool. I imaging the C-clamp has to be just the right size for it to work.
Old 01-02-2013, 05:46 PM
I tried two C clamps: Wilton 9", the pitch of the screw is too course. Harbor Freight 9", screw has a tighter pitch to it, welded a nut to the bottom of the screw rather than bending the crap outa the "T-handle" thing.
Neither worked. Of the two, the Wilton worked better, to a point. I'm thinking that I'll weld a nut to the bottom of the screw on it too and give it another shot.
Took the flat 'foot' thing off the screw and inserted the ball end of the screw into the socket of the torsion adjuster.
Old 01-02-2013, 07:05 PM
Half Success
I used the adjusting bolt to run the torsion adjuster up, held it in place with a clamp, removed the nut, slowly released the adjuster with the clamp.
Don't know how I'll put it all back together, but the taking it apart seems to be solved for now.
Old 01-03-2013, 03:25 AM
Although I haven't done it myself, I'm told that if you pop the lower ball joint from the steering knuckles and disconnect the shocks, that you can then swing the lower control arms down to further relieve pressure off the torsion bars. If you're doing one side only, then you would have to also disconnect the sway bar link on that side.
how do I get the torsion bar adjuster off torsion bar? turbo740922 1997 - 2003 F150 1 03-05-2011 05:34 PM
Transfer Case and Torsion Bars Rob_C Expedition & Navigator 3 09-03-2010 04:58 PM
2000 Expy 4x4 Ball Joints jhurd12 Expedition & Navigator 14 07-16-2008 03:48 PM
aftermarket torsion bars dogman Explorer, Sport Trac, Mountaineer & Aviator 0 10-30-2005 08:37 PM
removal of tranny and torsion bars? Merculous 1997 - 2003 F150 1 03-24-2005 10:41 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
