Perks56 F100 (R) build
Hope everyone had a Happy & safe New Years, & spent some quality time with their loved ones. That should have included your families & not just your beloved trucks.
I have posted in my Gallery photos of my build which took 6 years & 31 days to this point with a lot of minor finishing to do yet.
Started with frame, cab, & boxes of miscellaneous parts, no registration or VIN numbers just a sales receipt written on a scrap of paper.
With the great help of all of your fantastic information in reading hundreds of posts I was able to complete this build by myself with the exception of paint.
Lowered springs front & back 2 inches, sway bars front & back, lengthened shock mounts front & back, front disc brake kit, under cab power brake booster, Toyota power steering box, 1987 Mustang 5.0 L HO, AOD automatic, & 3.73 gears in stock rear end, Ididit chrome steering column, Grant wooden steering wheel, No Limit custom dash with VDO gauges, Vintage Air A/C Heater, & Pro's Pick Custom Tonneau.
To much more to list all the small stuff.
Hope you enjoy the photos, any questions on the build please ask.
P.S. My personal plate is coming in couple of weeks "KOOL 56" as that is what everyone has said first time they see it. Only 353 miles on it as I just got registration done and trying to break in the motor.
Thanks for all the help,
Kevin
Kevin
Perks56 F100 (R) Build comments
Thank you for the wonderful comments, it means a lot to me for comments coming from you folks on this site.
Everything I have seen built on here is beautiful work and I tried my best to do good job of mine as well.
It has been a great learning experience building this truck and you all have helped a lot as I did a lot of the items in my build because of reading about the work done by others on this site.
If I can ever help anyone else with info please let me know.
Kevin
Kevin
Louvered tailgate
Ben in Austin, thank you for the comments.
I had seen a Hot Rod done quite a few years ago with louvers like that and really liked it and so when I saw the Tailgate in Mid-Fifty's catalog with louvers and hidden latches that was for me.
I also got the matching roll pan to go with it and went without a rear bumper to showcase the tailgate and poll pan along with the LED taillights and roll lights.
They have numerous tailgates with louvers but wanted mine to make a statement but not be to outrageous.
Kevin
Kevin
Stock straight axle
Thanks Dano78
Left stock straight axle in, replaced all removable parts, and had springs front and back lowered 2 inches by local shop.
Brakes work fantastic, good stopping power with disc on front and rebuilt drums on back and underfloor power brake booster complete with remote fill reservoir behind drivers seat in panel, system self bleeds almost instantly.
Rear fenders are the 3 inch wider fibreglass, they fit and look very good. Went with them as I put 15 inch custom made wheels on truck. Front are 15 x 8 with 3 inch back set and rear are 15 x 10 with 4 inch back set American Racing Torq Thrust II - 5 on 5.5. Tires are 235/60R15 front and 295/50R15 rear FireHawk Indy 500
Kevin
Kevin
Thanks Dano78
Kevin
Kevin
You like the 'glass fenders? Local guy here has a set of 'steel' 3" widened rear fenders for sale... Haven't asked him 'how proud of them' he was, almost afraid to!
Fiberglass rear fenders
Dano78
At the time all I could find were the 3 inch wider fibreglass fenders, and I really wanted them for the look I was going for with the wider wheels.
Glad I got them though, they look fantastic and no one knows they are fibreglass unless I tell them. Biggest thing was I had a major BOO BOO one day moving the truck around in my shop on four wheel dollies when one flipped up and drove into the rear fender.
Just a small chip out of it that was sanded, filled and repainted so you can not tell it ever happened. If it had been steel fenders the whole corner would have been bent in with major damage and wouldn't be easy to fix so quickly.
When i put my 5.0 L HO engine in I put a dual sump oil pan on it and ended up splitting the sumps over my axle so I had a fair bit of clearance, can't take the pan off and out without undoing motor mounts but actually enough room that I installed the oil pump in position as the machine shop didn't put it in before they put the pan on and sealed it. That's a different story for another time. Thankfully I believe in preloading the oil pump and pressuring the oil system before starting an engine.
Kevin
Kevin
