6.9 Idi t19 pilot bearing
Old 01-01-2013, 08:58 PM
Brant Bowrifle's Avatar
Brant Bowrifle
Brant Bowrifle is offline
I'm thinking about swapping the t19 tranny out of an idi into another diesel. Been so long since I worked on that manual I can't remember exactly how the pilot bearing works. So I wonder if you guys could verify something for me, am I correct that the pilot bearing is in the flywheel and is independent of the crank? I've been working on transmissions with the crank bushing and I just can't remember if the idi's had anything like that. Appreciate the help. Thanks.
Old 01-02-2013, 04:42 AM
Eallend7's Avatar
Eallend7
Eallend7 is offline
Yeah the pilot bearing is seating inside the flywheel hole. Not attached to the crank, the nose of the input shaft goes into it
Old 01-02-2013, 01:31 PM
Brant Bowrifle
Thanks for verifying that. That transmission might be a good one to adapt over because I won't have to worry as much about flywheel spacing and mostly about making the bell housing adapter. Should make the starter easier to bolt up too. It would be nice if the flywheel bolt holes matched up in some way to the mercedes diesel crank, isn't a big deal, just be nice. Wonder if the starter for the idi would spin the smaller diesel a little to fast.... I like overkill though.
Old 01-02-2013, 05:42 PM
Eallend7's Avatar
Eallend7
Eallend7 is offline
Haha, your gonna have to get someone smarter than me in here to tell you all that! ;P
Old 01-03-2013, 02:55 AM
Brant Bowrifle
Smarter, maybe. But you are the kind gentleman that came to help, and for that I thank you .
moemoe598
11-11-2011 05:07 PM
littleroc
1983 - 2012 Ranger & B-Series
01-28-2011 06:27 AM
1988F-150
09-29-2009 08:17 PM
Ranger84
01-16-2006 09:50 AM
jds1971
07-23-2003 01:47 AM
Quick Reply: 6.9 Idi t19 pilot bearing
