2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
2009 leaking transmission
Old 01-01-2013, 04:21 PM
f100today's Avatar
f100today
f100today is offline
Just noticed the wifes expy is leaking tranny fluid. It only has 32k on it but has gone past the 3 year portion of the warranty. Or is there more than 3 year 36 on the powertrain? Anyway, I found the two TSB's about leaks. Is a TSB warrantied if the vehicle is outside the warranty window?
Thanks,
Tim
Old 01-02-2013, 05:41 AM
RI-Matt's Avatar
RI-Matt
RI-Matt is offline
I thought the original Powertrain warranty was for 5yr/60K and bumper to bumper was 3yr/36K.
TSB's are not generally warranty items, they are just bulletins to help techs diagnose and fix the problem faster. If the problem part or issue is covered under warranty then you should be covered. Make sense ?
I would think that a leaking transmission would be covered as the trans is part of the powertrain.
Matt
Old 01-02-2013, 07:53 AM
f100today's Avatar
f100today
Yeah, I found the warranty and it is 60/60 on the power train; so it is covered. And thank you for clarifying the TSB/warranty question.
Tim
MCDavis
General Automotive Discussion
16
10-07-2010 06:30 PM
trfdfirefighter
6.4L Power Stroke Diesel
06-07-2009 12:48 PM
ggwash21
2004 - 2008 F150
09-04-2008 02:24 PM
6ohin25401
02-13-2008 01:32 PM
elemint
10-09-2006 05:33 PM
Quick Reply: 2009 leaking transmission
