1st oil change - Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8
1st oil change
Old 01-01-2013, 09:24 AM
THUNDERBOLT64 THUNDERBOLT64 is offline
THUNDERBOLT64 is starting off with a positive reputation.
1st oil change
Hi all, just purchased a2012 F-250 6.2. When did everybody do there first oil change? The manual says 7,500 but that seems a little long for a break in period.
Old 01-02-2013, 10:16 AM
kmonty2's Avatar
kmonty2 kmonty2 is offline
kmonty2 is gaining momentum as a positive member of FTE.kmonty2 is gaining momentum as a positive member of FTE.
I did mine at 2000 then again at 5000. Now I am on every 5000 rotation. First one was free from the dealer.
Old 01-02-2013, 11:13 AM
tolliewolly's Avatar
tolliewolly tolliewolly is offline
tolliewolly is gaining momentum as a positive member of FTE.tolliewolly is gaining momentum as a positive member of FTE.
I did my first one at 3000 miles. After that I do 5000 miles. I am also doing my own at home. Use Ford racing oil filters and mobil 1.
Knowing I use synthetic I do sometimes run it on to 6000 miles. I know its early for syn but I dont care. I like doing maintenance!
Oil Question. wheelerg 6.0L Power Stroke Diesel 16 02-02-2014 01:14 PM
hpop oil change jccapri 1999 - 2003 7.3L Power Stroke Diesel 20 12-21-2012 10:35 PM
How much oil used between oil changes? Crewcab Turbo 1999 - 2003 7.3L Power Stroke Diesel 18 09-17-2011 03:25 AM
Oil Change Intervals UGA33 2009 - 2014 F150 1 11-17-2009 11:26 AM
Oil Change tomorrow Adam0331 1999 - 2003 7.3L Power Stroke Diesel 40 08-31-2008 10:09 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
