Turn Signal Flasher Location - Ford Truck Enthusiasts Forums
Old 12-31-2012, 10:19 PM
jnphobe jnphobe is offline
jnphobe is starting off with a positive reputation.
Does any one know where the Turn signal flasher is located on a 2011 F-350. I need to change it to LED compatible.
Old 01-01-2013, 02:06 AM
McFarlandkm McFarlandkm is offline
McFarlandkm is gaining momentum as a positive member of FTE.McFarlandkm is gaining momentum as a positive member of FTE.
The '11 and up models do not have a flasher relay, it is my understanding that the pcm controls this function. You will need a resistor atat each lamp for turn/run/brake lights
Old 01-01-2013, 05:06 PM
SteveC7010's Avatar
SteveC7010 SteveC7010 is offline
SteveC7010 is gaining momentum as a positive member of FTE.
Quote:
There's a Ford SVE specifically addressing this on the '11 and up Super Duty's. It is https://www.fleet.ford.com/truckbbas...ml/Q-158R3.pdf
Take the truck to your Ford dealer who will reprogram the BCM for LED's.
The SVE specifically addresses the front turn signals. It's unclear on the rears and you may still need resistors in the rear lamps. If the BCM sees a minimum of 700mA current draw, it won't think the lamps are out and enter "fast flash" mode.
What I am going to do is have the BCM reprogrammed and then try red LED's in the rear. If they fast flash, then I'll buy and add the resistors.
Last note: I know the SVE is for incomplete vehicles (sold to ambulance, etc. builders) but it should also apply to our trucks as well.
Old 01-01-2013, 05:55 PM
After reading the body builders attachment it looks like the BCM has to be reprogramed for both front and rear unless it was built as an incomplete vehicle that has the rears done from the factory.
Old 01-01-2013, 09:18 PM
madsonp's Avatar
madsonp madsonp is offline
madsonp has a good reputation on FTE.madsonp has a good reputation on FTE.madsonp has a good reputation on FTE.
I put rear LED's on mine and it works fine.
Old 01-01-2013, 10:05 PM
Learn something new everyday! Thanks fellas
Old 01-02-2013, 06:34 PM
Quote:
If you changed complete lights it probably works, I only changed the bulbs.
Old 01-02-2013, 07:22 PM
madsonp's Avatar
Quote:
You could be right. This is what I put one mine, they look pretty cool. Philip Lumiled 08 13 F250 F350 F450 F550 Superduty Red Smoked LED Tail Lights G2 | eBay
Old 01-03-2013, 09:41 PM
Well I had it fixed this morning, dealer wasn't sure till I showed them the SVE bulletin. They had it fixed in 20 minutes. Just turned off the light out indicator for both front and rear signals.
Turn Signal Flasher Location? FordTruckChuck 1997 - 2003 F150 1 08-10-2014 11:06 PM
Turn Signal Flasher tooldad 2004 - 2008 F150 1 01-04-2010 08:10 PM
emergency flasher location jjltraveler Electrical Systems/Wiring 3 03-03-2004 07:39 PM
turn signal flasher 2000 F-150 XL ohheflies 1997 - 2003 F150 1 02-16-2004 09:41 AM
Turn Signal Flasher fbclock Explorer, Sport Trac, Mountaineer & Aviator 2 02-25-2002 01:42 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
