throttle body injection vs. carburetor????? - Ford Truck Enthusiasts Forums
Old 12-31-2012, 09:16 PM
mrduke41 mrduke41 is offline
mrduke41 is starting off with a positive reputation.
Hello all, I am restoring a 78 bronco with a 400 in it. I am going to do a lot of off roading with this beast. it currently has a holly 4 barrel but i'm thinking of getting a throttle body injection system. my holley would give me problems on steep grades at low speeds. i would love everyones opinion on this subject. whats better, carb or throttle body injection? thanks in advance. duke
Old 12-31-2012, 10:54 PM
Raleigh1's Avatar
Raleigh1 Raleigh1 is offline
Raleigh1 has a great reputation on FTE.Raleigh1 has a great reputation on FTE.Raleigh1 has a great reputation on FTE.Raleigh1 has a great reputation on FTE.Raleigh1 has a great reputation on FTE.
I have a Holley Pro-jection TBI on my '79, what a huge difference! There is no comparison, response is much better and for off roading it is a must to have fuel injection.
Old 01-01-2013, 12:29 AM
greystreak92's Avatar
greystreak92 greystreak92 is offline
greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.
There is no comparison between carburation and fuel injection in my humble opinion.
There is no float, no fluid level to be maintained (and by "level" I mean gravitational level) which translates to not having starvation issues on inclines or off-camber situations which will happen with almost any carburetor and more so with the rather ungainly fuel reservoir(s) in the typical Holley unit.
Fuel injection is more precise metering which maintains better MPG overall. It is also very easy to troubleshoot and maintain given that there are no major adjustments to be made nor are there nearly as many seals and gaskets to fail. Fuel pressure needs to be higher but you can lose the leak-prone (fuel and oil) mechanical pump in the side of the block. If the problem is fuel delivery, its either a clogged filter the injector or the pump... end of story, barring any severe damage to the vehicle itself. No float to adjust, no choke to adjust, no idle settings to maintain, and best of all... no metering adjustments (i.e. jets, plungers, metering rods or whatever mechanical idiosyncrasies may be employed by any one of the hundreds of different carburetor makers out there).
I suppose that is my vote. In case it isn't clear, go with the fuel injection.
Old 01-01-2013, 09:17 AM
thanks a lot, looks pretty one sided. now i got to dig deep and make it happen. thnx duke
Old 01-01-2013, 04:43 PM
GruesomeJeans's Avatar
GruesomeJeans GruesomeJeans is offline
GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.
I do think fuel injection would be better for steep inclines and such, but I prefer carbs myself. Though mine is in terrible shape and doesn't run good, I am slowly learning how to tweak it for the better. I am kind of a novice with carbs, I had a 1 barrel on my 82 mustang and currently have a 4bbl carter AFB on my bronco. I think in terms of nor having to deal with adjustments, FI is the way to go. If you like to tinker with stuff and tweak it to run better, then carbs are the way to go.
Old 01-01-2013, 04:49 PM
thankd for the reply, thats a nice looking ride you got there.
Old 01-01-2013, 05:55 PM
Thanks It's my pride and joy. My first V8 vehicle and my first big truck with 4wd. Well somewhat. It's far from beautiful but far from junk
Injection question RedneckMisfit95 Ford Inline Six, 200, 250, 4.9L / 300 2 01-04-2017 01:17 PM
fast fuel injection system elkarcher1716 1973 - 1979 F-100 & Larger F-Series Trucks 2 11-04-2015 08:28 PM
1989 F250HD 351W throttle body cleaning... bebyb Large Truck 2 09-03-2014 12:09 PM
Holley Avenger TBI on a 300 I6 apachetech Ford Inline Six, 200, 250, 4.9L / 300 10 01-03-2012 11:53 AM
Howell Fuel Injection on an Y-Block TxF100 1948 - 1956 F1, F100 & Larger F-Series Trucks 7 06-24-2008 07:32 PM
Tags
carburator, fuel injection
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
