1978 - 1996 Big Bronco
1996 BRONCO ENGINE INSTALL QUESTIONS
Old 12-31-2012, 06:31 PM
robjs111's Avatar
robjs111
robjs111 is offline
Installing 351w into my 96 bronco with e4od but having issues connecting the two. I have motor on motor mounts and still about an inch away from transmission. The dowels on motor are aligned with transmission but cannot connect the two. What am I doing wrong?
Thanks.
Old 12-31-2012, 06:53 PM
robjs111's Avatar
robjs111
robjs111 is offline
Note: Is the TC supposed to spin freely installed on transmission? Right now I can TC and not sure if this is correct or does TC need to be seated further?
Old 12-31-2012, 07:14 PM
rudedogii's Avatar
rudedogii
rudedogii is offline
Torque Convertor
Check the TQ! Make shure it is seated all the way into the transmission!
Very important!
Old 12-31-2012, 07:16 PM
robjs111's Avatar
robjs111
robjs111 is offline
Very important!
Is there any way to tell when TC is seated correctly?
Thanks.
Old 12-31-2012, 07:33 PM
rudedogii's Avatar
rudedogii
Torque Convertor bolts?
Did you line up the TQ bolts to the flex plate? I had the same problem doing a trans install!
Old 12-31-2012, 07:51 PM
rudedogii's Avatar
rudedogii
TQ seated?
Thanks.
Check the first part of this video. Hope this helps or at least shines some light on your problem!
Old 12-31-2012, 07:54 PM
robjs111's Avatar
robjs111
robjs111 is offline
Will have to pull motor back out again and check if TC is seated correctly. I know for sure it spins freely and that might be a sign it is not installed right.
Also in video how did u spin flywheel or flexplate so easily to align TC bolts?
Thanks.
Old 12-31-2012, 08:02 PM
rudedogii's Avatar
rudedogii
I just used a socket and wrench on the crankshaft pulley!
Old 01-01-2013, 06:32 AM
cajunrebel's Avatar
cajunrebel
cajunrebel is offline
Where are the studs for the motor mounts? Have they gotten caught up on the crossmember or mount towers? You may have lowered them into a bind. A long mirror on a stick and a flashlight can really help you see where its hanging up.
GaMachinist
03-20-2014 10:39 AM
robjs111
10-21-2013 12:46 PM
dammford
10-22-2004 02:23 PM
bronco cam
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
15
04-28-2003 01:26 PM
screwy
12-21-2002 08:28 PM
Quick Reply: 1996 BRONCO ENGINE INSTALL QUESTIONS
