5.4 running lean - Ford Truck Enthusiasts Forums
5.4 running lean
Old 12-31-2012, 09:53 PM
BassFantasizer's Avatar
BassFantasizer BassFantasizer is offline
Dirty Old Man in training
BassFantasizer has a superb reputationBassFantasizer has a superb reputationBassFantasizer has a superb reputationBassFantasizer has a superb reputationBassFantasizer has a superb reputationBassFantasizer has a superb reputationBassFantasizer has a superb reputationBassFantasizer has a superb reputationBassFantasizer has a superb reputationBassFantasizer has a superb reputationBassFantasizer has a superb reputation
5.4 running lean
I've got a '97 F150 with a 5.4.
The truck started throwing a lean code. Checked the fuel pressure and it was low so I replaced the filter and got 2# back. Not enough so I put a new fuel pump in her.
Now she's throwing lean codes on both banks. Clear the codes, drive the truck for 20 to 30 minutes and the codes return. Run diagnostics while driving and the short and long trim voltages on both banks look normal.
So what's next?
Thanks,
Bass
Old 01-01-2013, 08:18 AM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
Vacuum leaks. Check/clean MAF.
If the fuel trims were normal, it wouldn't be setting fault codes for the mixture.
Old 01-01-2013, 09:30 AM
Thanks. Already checked for vacuum leaks and found none. MAF was next on my list so glad to hear someone back that up....
Old 01-02-2013, 10:47 PM
4x41977 4x41977 is offline
4x41977 is starting off with a positive reputation.
Mine threw codes saying it was running lean Nd looked all over for a vacuum leak. Someone on here told mme to clean the MAF sensor and that's all it was. They make a spray for cleaning it. Have been told only to use that and not cleaners such as brake cleaner.
Old 01-03-2013, 09:05 AM
Haven't had a chance to pull the MAF sensor yet. Probably this weekend.
The sensor's pretty delicate and costic cleaners would likely damage it, or even leave a deposit on it.
Old 01-03-2013, 12:42 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
Brake cleaner and MAF cleaners work good. Carb cleaner leaves a film. Just spray the filaments, don't touch. Also check the PCV hose elbows front and rear. The rear one tends to get overly soft and cracks.
Old 01-03-2013, 01:03 PM
I've always heard to stay away from brake cleaner. No matter though as I've got MAF cleaner and electrical component cleaner on the shelf.
I'm thinking that this won't solve it though. The truck also is a bit hard to start. When the truck is cold, you have to engage the starter for 1.5 - 2 seconds.
Old 01-04-2013, 08:46 AM
JWA's Avatar
JWA JWA is offline
JWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputation
Just asking a question here...............
Assuming the new pump gives acceptable pressure readings at the test point could this condition be related to worn injectors?
I don't know enough about these systems so forgive me if this is a foolish question!
Old 01-07-2013, 08:42 AM
Did cleaning it help?
Old 01-07-2013, 08:46 AM
It rained all weekend so I didn't get a chance to do it. Covered space at the house is at a premium.
Still on the radar for ASAP.
Old 01-22-2013, 05:29 PM
HjalmarOrn HjalmarOrn is offline
HjalmarOrn is starting off with a positive reputation.
q
Have you cleaned the MAF sensor yet?
Old 02-01-2013, 02:08 PM
Sorry for not getting back. The truck's been parked while I worked on other stuff.
Cleaned the MAF sensor, no change. After clearing the codes, the truck runs for about 20 minutes before the Check Engine light comes back on. 20 minutes continuous, two ten-minute trips, with or without complete cooling between trips. 20 minutes.
Both left bank lean and right bank lean are being thrown. Both of the O2 sensor's voltages/patterns look normal and regular on the graph.
~Bass
P0171 (Bank 1 Lean) and Random Misfires dclack Expedition & Navigator 10 11-18-2014 03:19 PM
Running Lean jfmaz 1987 - 1996 F150 & Larger F-Series Trucks 3 05-18-2014 09:58 AM
Fuel Trim BassFantasizer Modular V8 (4.6L, 5.4L) 12 12-08-2013 10:16 PM
Code P0174 system too lean bank 2... beekermartin 1997 - 2003 F150 29 01-24-2013 02:17 PM
5.4L F350 Code = P0506 Johnis 1999 to 2016 Super Duty 12 11-05-2009 11:52 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
