I smell gasoline
#31
I also discovered that my fuel line system is not original. I believe there once was a short piece of steel line running from the pump to a fitting on the feed line from the tank. This is evident because the fitting is still on the flared pipe just below and behind the radiator. A PO replaced that with the rubber hose (which rotted and was leaking).
jjacobs5623
03-06-2008 02:00 PM
76 F-150 390FE
12-11-2005 10:09 PM
