Brake Pedal Return Spring
Old 01-09-2013, 08:02 PM
mixup's Avatar
mixup
mixup is offline
On a 60 F100 was there a return spring on the brake pedal? If there was where does it connect?
Old 01-10-2013, 07:12 PM
spurredon's Avatar
spurredon
spurredon is offline
Yes there is. There is one on both the brake and the clutch pedal. They both attch. to a bracket that is bolted to the firewall in between the pedals for the lower end of the spring. The upper end of the spring attchs. up near the top of the pedal on the engine side of the pedal bushings. Not a very clear description perhaps. you might want to consider buying a shop manual, available on Ebay and other etc...
Old 01-10-2013, 10:13 PM
mixup's Avatar
mixup
mixup is offline
Thanks for the information. I have the bracket on the pedal but I didn't know where the bottom bracket went.
Old 01-11-2013, 04:53 PM
F-100CustomCabTBC's Avatar
F-100CustomCabTBC
F-100CustomCabTBC is offline
Here's one of the best pictures I have of the bracket and spring.
Old 01-11-2013, 06:53 PM
mixup's Avatar
mixup
mixup is offline
Great picture, Thanks.
66ordie
12-27-2018 05:55 AM
tvliftcabinet
06-28-2017 03:47 PM
P38fighter
09-18-2012 06:38 PM
OregonJen
1947 and Older Ford Trucks
06-12-2012 04:58 PM
1949f47
02-24-2003 09:59 PM
Quick Reply: Brake Pedal Return Spring
