engine smoke - Ford Truck Enthusiasts Forums
engine smoke
Old 12-31-2012, 04:28 PM
blkfordtruck blkfordtruck is offline
blkfordtruck is starting off with a positive reputation.
engine smoke
I have a 1977 f-150. When driven every day the truck runs perfect uses about a qt. of oil every 2 months. If the truck is not started for about a week white smoke just boils out of the exhaust like a mesqito fogger for about 2 or 3 minutes.
Whats going on?
Old 12-31-2012, 04:40 PM
ahapp88 ahapp88 is offline
ahapp88 is starting off with a positive reputation.
White smoke means water is getting in the combustion chamber somehow. Black smoke is fuel, blue smoke is oil. Can't say where it's coming from, but white smoke is definitely water. I would drain the fuel bowls and gas tank myself before looking internally. I'm no ASE tech, just my .02
Old 12-31-2012, 05:04 PM
nine inch rear nine inch rear is offline
nine inch rear is starting off with a positive reputation.
You probably have worn valve guide seals. But if you want to rule out coolant problems, there are two ways. One is a bit quicker than the other. 1st way is to remove all spark plugs. Pressurize cooling system with a pressure tester. Let it sit over night. Crank the engine over and look for coolant spitting out of spark plug hole. 2nd way which I like better is to get a compressed air into each cylinder and watch for bubbles coming up through the radiator neck. Valves need to be closed, so either pull the valve covers or turn the engine over till your coming up compression stroke. There are block testers that turn the blue dye to yellow, but Ive found they arent always accurate. Any spark plug you remove that has rust on the threads and electrode, that cylinder could be compromised with coolant
Old 12-31-2012, 05:23 PM
Dasher400's Avatar
Dasher400 Dasher400 is offline
Dasher400 is gaining momentum as a positive member of FTE.Dasher400 is gaining momentum as a positive member of FTE.
Ditto on the above... also just check your dipstick for gray or milky oil. some condensation is typical if your just doing short trips, but if your oil is graying, your probably looking at a head gasket or cracked block (if its white smoke). The plastic/rubber (whatever they are) valve seals get brittle over time and are notorious for breaking. That allows oil to get down into the piston while the truck sits (especially if its sitting on a sloped driveway).
IMHO, a quart every two months; now that much I could live with. Especially if you're driving it every day.
Old 12-31-2012, 11:29 PM
mark a.'s Avatar
mark a. mark a. is offline
mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.
Is the coolant level going down ? Are you having to add to it ?
Old 01-01-2013, 11:54 PM
Sorry I should have said blue gray smoke. It is for sure oil its burning. I will check them valve seals. Thanks everyone.
Bar's Leaks Head Gasket Stop Leak? Sean_Reno Ford Inline Six, 200, 250, 4.9L / 300 4 10-07-2015 08:31 PM
Gradual loss of power 2danglong 1999 - 2003 7.3L Power Stroke Diesel 8 09-25-2015 09:00 PM
Excessive blue smoke under load? EcoboostKev 1999 - 2003 7.3L Power Stroke Diesel 9 05-25-2015 10:56 PM
engine smoking 77 2wd 1973 - 1979 F-100 & Larger F-Series Trucks 6 11-04-2012 08:03 AM
6.0 Stalling/Spitting and Sputtering coderis 6.0L Power Stroke Diesel 10 09-09-2005 10:37 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
