cdr on my 7.3 - Ford Truck Enthusiasts Forums
cdr on my 7.3
Old 12-31-2012, 01:26 PM
1989f250IDI's Avatar
1989f250IDI 1989f250IDI is offline
1989f250IDI is starting off with a positive reputation.
cdr on my 7.3
i went to my local part store and they promise me my truck has nothing on it called a cdr. Which i know it does. How do i go about getting one? Will it have any effect on my engine besides my oil consumption?
Old 12-31-2012, 01:37 PM
IDIDieselJohn's Avatar
IDIDieselJohn IDIDieselJohn is offline
IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.
You can try removing it, and letting soak in gasoline for a few hours, taking it out and shaking it every 20 min or so during those hours, to clean it up. But it wouldn't be a bad idea to get a new one.
I think the CDR is a Ford or IH dealer part only.
But yes a bad, or dirty CDR will cause oil consumption.
Old 12-31-2012, 02:53 PM
Raleigh1's Avatar
Raleigh1 Raleigh1 is offline
Raleigh1 has a great reputation on FTE.Raleigh1 has a great reputation on FTE.Raleigh1 has a great reputation on FTE.Raleigh1 has a great reputation on FTE.Raleigh1 has a great reputation on FTE.
I was looking for a replacement for mine, no dice so far. I will check the dealer, thanks
Old 12-31-2012, 11:54 PM
tecgod13 tecgod13 is offline
tecgod13 is gaining momentum as a positive member of FTE.tecgod13 is gaining momentum as a positive member of FTE.
Its pretty much a dealer only part these days, and not as cheap as it should be
Old 01-01-2013, 12:18 AM
whiteboyslo's Avatar
whiteboyslo whiteboyslo is online now
whiteboyslo is gaining momentum as a positive member of FTE.
Dealer part, but they won't call it a CDR valve. Here's the Ford PN: E3TZ-6A665-A
Mike
Old 01-01-2013, 12:23 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT FORDF250HDXLT is offline
FORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant future
ford E3TZ-6A665-A
E3TZ-6A665-A - Ford ADAPTOR
navistar international 1805319C1
1805319C1-NAVISTAR-VALVE
happy new year!
Old 01-01-2013, 12:36 AM
Raleigh1's Avatar
Holy crud, that is expensive! The hose from the valve cover to the CDR is cracked on mine, I think I will try to clean with some ATF and acetone mixed (best solvent ever!) before I drop $90 for one...
Old 01-01-2013, 02:17 AM
yeah.so many of us would faint if we had to maintain a powerstroke.
did ya see the first link though,it's 50 there.much better,but still does seem silly high for such a basic device.
i know you can wash 'em out,but your not supposed to used compressed air,and if you see black chunks coming out while washing,that's when you know you need to replace it i guess.still haven't bothered to wash mine yet so i dunno.
Old 01-01-2013, 04:40 AM
vfelix702's Avatar
vfelix702 vfelix702 is offline
vfelix702 is gaining momentum as a positive member of FTE.
I bought the tube and gromet at ford when I cleaned mine
Old 01-01-2013, 10:36 AM
Raleigh1's Avatar
Quote:
This si what I am planning to do, a quick look at it when I had it off Sunday it appears to be in good shape.
Just Blew My CDR Diaphragm mechelement Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 9 06-05-2014 12:39 AM
cdr pipe size d-day Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 0 12-25-2013 10:39 AM
CDR grommet Eallend7 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 7 03-10-2013 12:06 AM
cdr 1989f250IDI Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 15 11-19-2012 11:52 PM
Can CDR valve cause no start? Blitzcraig Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 8 02-24-2012 11:58 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
