2001 F150 Fuse Panel - Ford Truck Enthusiasts Forums
Old 12-31-2012, 09:12 AM
Mister N Mister N is offline
Mister N is starting off with a positive reputation.
Lightbulb 2001 F150 Fuse Panel
Hey guys, I've got a general fuse panel question. I have a number of "not used" locations on my fuse panel. My question is, are these locations wired as if they were? Meaning, is power going to those locations on the fuse panel even though there is no fuse in the slot?
I want to add some off road lights and rather than run a wire directly to the battery or piggy back off a fuse that's already powering something, I'd like to use one of the "not used" locations.
Thanks ahead of time,
Keith
Old 12-31-2012, 09:40 AM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
Look at the open spaces to see if there are metal contacts. If so, probe them with a test meter or lamp to see what might be hot.
Help with 2002 F150 fuse panel {location of fuses} topdog49646 1997 - 2003 F150 2 09-06-2016 04:54 PM
Question: 2015 Passenger Compartment Fuse Panel RightWingNutJob 1999 to 2016 Super Duty 0 07-13-2015 11:30 AM
04 Upfitter switch fuse locations xmontex4 1999 to 2016 Super Duty 3 07-20-2013 10:36 PM
Installing electric fuel pump abriel68 1987 - 1996 F150 & Larger F-Series Trucks 8 02-13-2013 03:43 PM
fuse panel garyh8 1987 - 1996 F150 & Larger F-Series Trucks 3 08-17-2011 10:09 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
