1991 F350 2wd to 4wd straight axle conversion - Ford Truck Enthusiasts Forums
View Poll Results: Is the conversion worth it on this truck?
YES 1 33.33%
no 2 66.67%
Multiple Choice Poll. Voters: 3. You may not vote on this poll
Old 12-31-2012, 09:33 AM
F350buckeye F350buckeye is offline
F350buckeye is starting off with a positive reputation.
Hi everyone I bought at an estate auction a 1991 F350 crew cab XLT with 64k miles no rust, great body and interior and new tires, has a 460 v8 w/auto tranny. I bought the truck in March 2012 for $2,500 I was at the auction to by other items and then the truck hit the block and I was the second bid and the last. I thought that was pretty cheap for a truck in this condition and that was it I bought the truck. I am a farmer and desire this nice truck to be 4wd with a straight axle but have no idea where to start. Can someone please offer any advice for my potential project? I am mechanically inclined and feel I could do this project with some pointers.
Old 12-31-2012, 10:31 AM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
You need a donor truck
You will need the following
D60 front axle from a 85.5-97(axle, track bar, track bar mount, drivers side u-bolt plate, steering linkage)
F350 leaf springs from a big block or diesel
4wd auto trans from a 460
transfercase
rear driveshaft and front driveshaft
Spring hangers for the FRONT leaf springs(the rear ones that will go under the front cab mount)
Front ones that will also get bolted in on the inside of the frame. 3 bolts we replace 3 rivets that hold the rad support bracket on and you will have to drill 3 more holes(srping hanger is held on w 6 bolts) You will also have to notch the bottom of the frame for the shackle to go in.
OR for the front hanger you can box the frame and use a SKY Manufacturing RSK for the front hanger
You can PM Brown Falcon. he did almost the identical swap http://www.ford-trucks.com/forums/member.php?u=474911
Old 12-31-2012, 10:57 AM
fdude64's Avatar
fdude64 fdude64 is offline
fdude64 is gaining momentum as a positive member of FTE.
welcome to fte, also from the donor truck you will need the lift blocks from the rear axle for the stock 4x4 lift. 2wd didn't get the blocks. what part of ohio are you in, I am near dayton
Question on F100 & F150 trucks 80-86 FuzzFace2 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 22 12-02-2015 11:02 PM
Parts for Auction 54TexasF100 1948 - 1956 F1, F100 & Larger F-Series Trucks 7 10-08-2015 01:09 AM
Power Brake Upgrade for 66 F250 AubreyA3 1961 - 1966 F-100 & Larger F-Series Trucks 6 01-30-2015 11:39 AM
Mods, Maintenance, and Life(long and kind of pic heavy) redman84 1994.5 - 1997 7.3L Power Stroke Diesel 17 05-29-2013 01:38 PM
New Used Truck (gloating) xoloski 1987 - 1996 F150 & Larger F-Series Trucks 12 01-14-2011 09:04 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
