Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > 6.2L V8
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8 SPONSORED BY:
  #1 (permalink)
Old 12-31-2012, 02:33 AM
oneaddicted oneaddicted is offline
Garage is empty, add now
oneaddicted is starting off with a positive reputation.
thinking of changing from 6.0 diesel to 6.2 gas
hi guys! new user. i currently have a 2006 f350 6.0 diesel cc fx4 4x4 dually. truck has 330,000 miles with original drive train.everything working fine buy the way. thinking of buying 2013 f350 reg or super cab with 6.2 gas. been looking at mileage posts on here. my 6.0 has 4.30 gears it gets 14 @ 70 empty and 10 to 11 towing, 6000 to 10,000 lbs. i own an rv transport business so i tow pretty much every day. it's time for a new truck diesel is a lot $ to maintain. i knw i'll loose some of towing power on hills but new diesels are 60k. any thoughts? any one else go from diesel to gas ???
  #2 (permalink)
Old 12-31-2012, 03:03 PM
biz4two's Avatar
biz4two biz4two is offline
biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.
Arrow
IMHO...in your line of business...I'd stick with a diesel. The 6.7L is really a GREAT engine...and your fuel mileage will increase some.
If you are serious...then I recommend jumping on a 2012 6.7L with all the discounts and rebates offered. That will save you a ton of cash...
As much as I like my 2012 6.2L...I would not tow heavy with it every day. The fuel mileage would eat the profit line.
Just my .02 here...
Good luck either way...
biz
__________________
2012 FORD F250 SD CC 156" Lariat FX4 6.2L BOSS 4x4 4.30s
2003 F250 SD SC 142" XLT FX4 V10 Auto 4x4 3.73s -- Traded
1976 F150 LWB Custom 4x4 390FE NP435 3.50s
  #3 (permalink)
Old 01-01-2013, 10:06 AM
txtruckin txtruckin is offline
2001 Ford F-250
txtruckin is starting off with a positive reputation.
I use a V10 in the same line of work, and am having trouble deciding if another gas truck or a diesel will be next, MPg numbers for you, Lowest ive see was 6.3 and the highest was 8.1. Depending on the weather.
__________________
[SIGPIC]2001 Ford F-250, crew cab Lariat, V10, Auto, 4.30`s, 60 gal aux tank.
38` Escaper Fiver, 14,000 lbs
  #4 (permalink)
Old 01-01-2013, 12:42 PM
THUNDERBOLT64 THUNDERBOLT64 is offline
THUNDERBOLT64 is starting off with a positive reputation.
For what you use it for I would go Diesiel. Love my v10 and my 6.2 but I only tow 8 to 9k.
__________________
2012 f-250 XLT 4x4 Reg cab 6.2 Golden Bronze
2007 f-250 XLT 4x4 SC SB V10 Dark Stone Metalic
1991 Mustang LX hatch 306 Vortec V1 10.27 @131 mph
1991 Mustang LX Coupe Wild Strawberry 5sp.
  #5 (permalink)
Old 01-01-2013, 02:40 PM
truckfella truckfella is offline
truckfella is starting off with a positive reputation.
oneaddicted: I would tend to agree with what others have said. Given your line of work, a diesel probably makes most sense for you in the long term.
But, if I may ask...
1) Where are you located? Are you usually/typically pulling over mountains?
2) What is the typical size of the RV you transport? Are most the big, 35'+ 5ers?
3) What are the typical differences in gas vs. diesel prices where you reside?
4) I would imagine at 330k miles, your 6.0 is getting somewhat tired. Have you considered swapping in a newer 6.0 power plant? Or is the rest of the truck just as tired?
By the way, I went from a diesel to gasser myself in the past few months (to a V10). But I don't tow nearly as often as you.
__________________
2003 F350 V10 CC/LB Lariat 4x4, Auto w/ 3.73 axles, 285/75/16 tires. 85k miles. Software by Mike at 5Star! Up next: 3.73 swap for 4.30
Arctic Fox 811 slide-in camper (4000lbs)
  #6 (permalink)
Old 01-01-2013, 03:42 PM
fordmdb's Avatar
fordmdb fordmdb is offline
PREMIUM SPONSOR
fordmdb has a very good reputation on FTE.fordmdb has a very good reputation on FTE.fordmdb has a very good reputation on FTE.
The 6.2L would tow just fine, Might use a little more fuel than diesel.. 2 more mpg maybe but it would do the job. my 2 cents.. OR you could wait for the SD to get the 5.0L EB motor thats rumored to be 14-15 model. Again rumor is..
__________________
Custom Tuning for F-E-Series Engines 6.8L V10 / 5.4L V8 / 4.6L V8 / 6.2L V8 / 5.0L V8 / 3.7L V6 / 3.5L EB and more!
SCT Custom Tuning Dealer
www.5startuning.com email me here:mike@5startuning.com 843-536-1244
  #7 (permalink)
Old 01-01-2013, 08:43 PM
i'll be calling you about tunning one, i have some ? thanks for in put
  #8 (permalink)
Old 01-01-2013, 09:00 PM
i live in lower desert in calif. sometimes tow big ones, but mostly 6-10000 lbs. know a guy with a dodge 5.7 3500 flatbed 6spd man he does same thing. gets worse mpg towing but better coming home empty. if it got 15-16 empty i'd be the same. but up keep is less. yes 6.0 getting tired, not super bad but worn none the less. huge $ to fix though. just lookin at other idea's. the guy with gas 3500 came from cummins with 440,000 says he'll never go back. very little problems, no so with diesel and i maintenance mine religiously.still issues.
  #9 (permalink)
Old 01-01-2013, 10:11 PM
Flatbed Ed Flatbed Ed is offline
Flatbed Ed is starting off with a positive reputation.
Quote:
I would stick with a diesel. It was quite a shock for me to go to the 6.2 gas after driving my 6.4 with H&S Tuner with 400 plus HP. On the other hand, if you put a 5 Star Tuner on it with 4.30 gears........that set up I believe would work!
__________________
2012 F-350 Chassis Cab,12-ft flatbed,6.2 gas
X-PSD driver, done with diesels
  #10 (permalink)
Old 01-01-2013, 11:36 PM
jerem0621 jerem0621 is offline
1999 Ford F-350
jerem0621 is gaining momentum as a positive member of FTE.
6.2 would do just fine.
I think the others are missing a very important component to deliver work. Rig down time means no money coming in.
A $5,000.00 diesel repair could be 1-3 weeks of down time. Suddenly that $5,000.00 repair really cost 7-15k with the down time. (down time = no work)
IMHO.. we will start to see an increase in gassers in this line of work. There are many fleets who are going with gassers to replace diesels... I wonder why?
The 6.2 gasser would be a very wise decision OP.
  #11 (permalink)
Old 01-02-2013, 05:07 AM
smote smote is offline
smote is starting off with a positive reputation.
I've also noticed in my area that more and more of the works trucks are gas these days. Even starting to see some of the Eco-Boost F150's as work trucks.
I currently have an old 96 dodge diesel that we mainly just use for truck duties and camper pulling. I'm thinking we may switch to gas next time since the truck as so much cheaper and we don't drive it much anyway.
  #12 (permalink)
Old 01-03-2013, 04:47 PM
HideoutJP HideoutJP is offline
HideoutJP is starting off with a positive reputation.
I went from a:
2003 7.3L PSD
2WD CC 6.5 ft. bed
to a:
2011 6.2L 3.73 rear end
4WD CC 6.5ft bed
and I love it. I still hear it almost daily for letting the diesel go but it was time. I do not use my truck near as hard as you do pulling trailers every day. With that in mind I pull a 27 ft. toy hauler. This toy hauler has steel in it. It was made with strength as the first priority, and weight as an after thought by Kit manufacturing. Empty, I put it on the scales and it was 8700 lbs. If I load it with my four wheelers and camping material I am ~ 10,750. My 7.3 would get 8 MPG towing 65-70MPH. My 6.2L gets........ 8MPG towing 65-70MPH. NOw as far as performance, the 6.2L obviously won't run in 6th gear uphill and maintain speed but I lock 6th out and have it in tow/haul mode and tow with no problem.
Towing 10,000 pounds in the 6.2 in 5th gear between 65-70 I'm running high 2000RPM. If it kicks down to 4th gear it's still only about (I say about because I did not take pictures, it was a mental note) 3250 RPM. NO where near the 5000+ redline and it never has a problem.
NOw a key disclaimer, I live in Kansas so hills are low and long so nothing steep. Just my experience in my truck. Towing everyday across country could be different, but for what its worth this is my story.
  #13 (permalink)
Old 01-05-2013, 09:27 AM
Snowman 8 Snowman 8 is offline
Snowman 8 is starting off with a positive reputation.
I went from an 06 with a 6.0 to a 12 F350 with the 6.2. The diesel has more power and will get better mileage but it is kinda nice not to have my truck in the shop for a few weeks a year! I get 5-6 mpg while pulling our skid steer trailers and 10-11mpg empty, but gas is cheaper than diesel fuel and the 6.2 hasn't been in the shop yet with 43000 miles on it. You will be fine with the swap you just have to realize the 6.2 won't pull loads as easily as the Diesel engines but it will get you where you need to go. I have also pulled our mini-excavator quite a bit the engine will pull the trailer as fast as you want to go it just works a little harder. I think that trailer is close to 16000lbs, the tag on the mini-ex says it weighs just over 13000 lbs and the trailer is around 3000lbs.
  #14 (permalink)
Old 01-05-2013, 01:15 PM
Mr. Mcbeevee Mr. Mcbeevee is offline
Mr. Mcbeevee is starting off with a positive reputation.
I very good point indeed. This is why my company fleet went to all v10 trucks for class 5 and lower. Not only were the repair bills terribly expensive on the diesel trucks, but when they were in the shop they still had to pay us. So far on mine after 2 years and 45,000 miles it has been in the shop once, and this was for a bad computer.
__________________
2011 F-150 S-Crew EB 4x4 (Wife’s)
2003 Escape 4x4 3.0L (Mine)
2001 F-250 4x4 5.4L 5speed (little farm truck)
1991 F-800 429 dump 5+2 speed (big farm truck)
1952 8N
  #15 (permalink)
Old 01-05-2013, 03:22 PM
rvpuller's Avatar
rvpuller rvpuller is online now
2013 Ford F-350
rvpuller has a good reputation on FTE.rvpuller has a good reputation on FTE.rvpuller has a good reputation on FTE.
oneaddicted you may also look at the F450 with a V10 but you will have to put a bed on it. I,m looking at going that way maybe in late spring but I'm also still looking at the 6.2.
Denny
__________________
2013 F350 Lariat SC DRW 2WD 6.2 4.30 Gears
2003 HH Premier 35 FKTG
Retired 2000 F350 Lariat SC DRW V10 4.30 Gears BrakeSmart
Air Lifts 4X2
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
