NEED HELP!! - Ford Truck Enthusiasts Forums
NEED HELP!!
Old 12-30-2012, 08:34 PM
shorty6545 shorty6545 is offline
shorty6545 is starting off with a positive reputation.
NEED HELP!!
hey there hoping u guys can help im trying to rig up an older fisher plow on my 94 f150 shorty but having some difficulty getting the pump mounted and running it has an inline 6 engine what ive done is take the serp pully off my seized smog pump and welded it to the front of the v pulley that came with the plow pump so i can just run it off of my serp belt rather than trying to make the v pulley work so got the belt for trucks with a/c but belt was quite a bit too long i mounted the pump under the power steering pump any suggestions??? thanx in advance
Old 12-30-2012, 09:38 PM
deljac's Avatar
deljac deljac is offline
deljac is gaining momentum as a positive member of FTE.deljac is gaining momentum as a positive member of FTE.
Welcome to fte. Sounds like your question is belt lengh. Take a piece of rope and run it around like the belt would go and back to itself. Then measure the lengh and go to your local parts store and tell them the lengh and they shud be able to get you a belt. Goodluck
Old 12-30-2012, 09:47 PM
thanx was going to try that but wasnt sure how accurate the rope would be but i will give it a shot tomorrow
V-belt PS pulley ? swimnshoot Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 8 07-18-2012 10:04 PM
Water Pump Idea's 5.4 Expedition jwhopson 1997-2006 Expedition & Navigator 4 08-11-2010 09:36 PM
power steering pulley problem powerstroker100 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 12 07-20-2010 02:03 AM
Serp. Belt. Tension Needed--'97 F-250/460 BigSix1 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 2 10-10-2008 09:14 AM
Fan nut removal?? Supercab 1999 - 2003 7.3L Power Stroke Diesel 21 09-24-2008 01:07 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
