2004 6.0 shifting and stalling issue
I have a 2004 f250 6.0 That feels sluggish and requires lifting off the accelerator to upshift, if not then it seems not to shift until 3k or more rpms. After driving for about 20-30 minutes the truck will start bucking and trying to stall while driving. Sometimes if I pump the accelerator the truck will try to stay running, but sometimes dies requiring to come to a full stop and place in park to start back up. I plan on getting it to ford to have it looked at, but was wondering if anyone here has any ideas? There is also no check engine light being thrown at all.
The 6.0 and tranny are robust units but require **** maintenance. I would start by changing all fluids and use only OEM filters. Stay with SP or LV in the tranny. I'd also go with the 5W40 oil since you have no idea about the past maint. history. You need a starting point on the maint. You'll also need a monitoring system such as a ScanGauge ll at a min. to see what's going on with the engine and electronics, mainly the ficm and temps. The factory gauges are no better than idiot lights.
Ford3673
1999 to 2016 Super Duty
05-06-2019 05:27 PM
