Gas Tank Under the Bed & Filler in the Fender: How to Route It?
Looking for ideas on how to route the filler hose through or around the frame to a filler door that will be grafted into the fender. Pictures would be great.
Does anyone know how much clearance there is between the frame rail and the underside of the bed once it's installed (I don't have all the pieces yet or I'd check myself). Wondering I could just squeeze the rubber hose between them or if it would be pinched too much.
1970 Mustang tank with the filler inlet right at the back of the bed, routed to the left fender and a round fuel door from a mid 90's Chevy truck.
The links below are from a former , Randy Walker, who passed away this year - A reproduction of his design would be a tribute to a wonderful person and an expert builder
1956 Ford F100 4x2 - Rear Gas Tank
1956 Ford F100 4x2 - Gas Filler Door
It would help tremendously to know what you are working on; make, model, year, etc. We're not mind readers.
On my 49 F1 I mounted a late model Suburban tank under the bed, routed the fuel filler hose between the bed and frame towards the passenger side and used a marine style filler neck in the right rear fender.
On the 48-52 trucks there is approx 1 1/2 to 2 inches between the bedfloor and frame, however you do have to massage the bedside panel a bit as it hangs down below the bed floor.
Bobby
Bobby
Ah, that's where I first saw the gas door in the fender. I'm not sure I like notching the frame but it's hard to argue with success.
Well that's disappointing.
1949 F-1, 1970 Mustang tank between the frame rails behind the rear axle.
I had initially looked at the Mustang tank but I didn't want the fuel filler in the bed floor. Here's a shot of the bed on the truck without a bedfloor, you can see the relation of the frame and the bedsides. I circled the area of the bedfloor that I massaged for clearance of my filler tube.
cvorden
25
08-19-2016 07:07 PM
Jeff Olsen
11-26-2011 03:14 AM
keyul
05-18-2011 04:53 PM
Randy Jack
20
08-25-2006 01:48 PM
Trader Bob
16
05-22-2004 11:18 PM
