my 1977 F150 4x4 build... how we do it down under - Ford Truck Enthusiasts Forums
Old 12-30-2012, 09:10 AM
Aussie_F_trucker's Avatar
Aussie_F_trucker Aussie_F_trucker is offline
Aussie_F_trucker is starting off with a positive reputation.
G'day folks.
Haven't really been on for a long time unfortunately. Work seems to get in the way of playing trucks.
For those who don't know me, My name is Elliott and i live in Western Australia. About four years ago now i picked up a 1977 F150, 351C 4spd 4x4 running on LPG with a flatbed.
this is it soon after i bought it.
at the time it had 33x12.5 BFgoodrich ATs on it and 3.55:1 gear ratios.
further down the track, i converted it to a styleside box and added a racerback that i picked up cheap. around the same time i put on some 35x12.5 mickey thompson MTZs on some nice alloy rims.
Now here is when things started getting out of hand...
i bought a 6'' superlift kit off a friend of mine with a view to run 37'' to 39'' rubber.
then another friend of mine found some 42x14x17 Super Swamper IROKs and a set of TrailReady beadlock rims.
Not long after that picture was taken, i took the old girl for a blast and mysteriously lost power to the front wheels.
now before anyone says anything, I KNOW i was stupid for putting such massive tyres on without upgrading gear ratios and then planting my right foot in it out in the sticks LOL.
Long story short, the damage was the right hand axleshaft u joint, and destroyed spider gears in the diff centre...
And as they say, if it breaks, build it stronger.
So then i started the online spend-a-thon through Summit racing and Jeffs Bronco Graveyard (both oustanding businesses).
I'd decided that i would go with 4.56:1 ratios front and rear (as i plan to run 38's on a more regular basis) and put diff lockers in front and rear.
this was taken at the beginning of this week, when i started the teardown process. I'd decided i was going to do front and rear diffs, a 79 front end facelift and twin stick the transfer case as well as clean up a few odd and ends.
taking the front axle out on thursday night (too hot to work during the day here). i wonder if it knows im unhappy with it? I've been building the new axle for a while now, 4.56:1 gears and an air actuated Yukon Zip locker.
completed today was the 79 facelift with H4 bulb conversion headlights from Bronco Graveyard.com.
looks far more aggressive than the 77 front end IMO.
as it stands, thats all I've done for the time being.
today i installed the Spartan Locker in the rear diff centre and fitted up the 4.56 ring gear but thats about it. hoping in the next couple days to get the new front axle installed and remove the transfer case so i can modify the internals for the twin stick conversion, as well as gather up the courage to cut my fenders up to fit my Bushwacker cutout flares.
thanks for looking and please feel free to share your thoughts on my truck! I'm always open for constructive criticism
Old 12-30-2012, 09:35 AM
parkerparkerm parkerparkerm is offline
parkerparkerm is starting off with a positive reputation.
May I request that you go into specifics as take lots of pictures for the twin stick and fender cutting? Gonna subscribe to this one fo sho!
Old 12-30-2012, 09:38 AM
Definitely! Both those parts are new to me as well so I'll make sure I do that for you
Old 12-30-2012, 10:01 AM
Ok awesome! Looking forward to seeing this done
Old 12-30-2012, 10:05 AM
tbear853's Avatar
tbear853 tbear853 is offline
tbear853 has a very good reputation on FTE.tbear853 has a very good reputation on FTE.tbear853 has a very good reputation on FTE.
So KOOOOL this is .... but should keep the Gen'l Lee look!
Subbed!
Old 12-30-2012, 12:21 PM
vic_v8 vic_v8 is offline
vic_v8 is starting off with a positive reputation.
it may just be my eyes or the pic, but it looks like you had a steering stabilizer installed kind of goofy in one of the pics.
Old 12-30-2012, 01:17 PM
KingBigJoe's Avatar
KingBigJoe KingBigJoe is offline
KingBigJoe has a superb reputationKingBigJoe has a superb reputationKingBigJoe has a superb reputationKingBigJoe has a superb reputationKingBigJoe has a superb reputationKingBigJoe has a superb reputationKingBigJoe has a superb reputationKingBigJoe has a superb reputationKingBigJoe has a superb reputationKingBigJoe has a superb reputationKingBigJoe has a superb reputation
Hmmm... Nice intro. Subscribed...
Old 12-30-2012, 01:30 PM
Roger Carter's Avatar
Roger Carter Roger Carter is offline
Roger Carter is gaining momentum as a positive member of FTE.
Interesting build. I enjoy seeing how "the other side of the world" approaches these trucks.
Is the truck a right hand drive or left?
Roger Carter
Old 12-30-2012, 02:33 PM
f250custom78's Avatar
f250custom78 f250custom78 is offline
f250custom78 is starting off with a positive reputation.
subscribed
Old 12-30-2012, 07:07 PM
Its a right hand drive truck (I'll put up some interior pics when I'm doing some work on it). The steering stabilizer is actually hanging on one end in one of the pics. I can't actually remember the reason for it though lol.
Old 12-30-2012, 07:25 PM
77460ford's Avatar
77460ford 77460ford is offline
77460ford is gaining momentum as a positive member of FTE.77460ford is gaining momentum as a positive member of FTE.
Could you also take a couple pics of your LPG setup. Looking forward to seeing it bolted back together.
Old 12-30-2012, 08:20 PM
73 ford guy's Avatar
73 ford guy 73 ford guy is offline
73 ford guy has a great reputation on FTE.73 ford guy has a great reputation on FTE.73 ford guy has a great reputation on FTE.73 ford guy has a great reputation on FTE.
That poor steering....gonna need some help.
Old 12-30-2012, 10:50 PM
Dual stabilizers oughta do the trick. It has factory powers steering.
Old 12-30-2012, 11:33 PM
Dual stabilizers are a bandaid fix for bumpsteer. After the bigger tires were put on u can't honestly tell me steering is fine. On my big truck on 44's I went crossover ,with highsteer,Saginaw power steering pump with modified internals for high flow, and hydro assist with a 1.5" x8" ram...no stabilizers. I can say steering is perfect,lots of power and has zero wondering at high speeds.
Old 12-30-2012, 11:38 PM
How would full hydraulic steering go on a dent?
My crew cab swap pics dukedrummer89 1987 - 1996 F150 & Larger F-Series Trucks 39 01-06-2016 08:58 PM
Winter Time! Stancor GPR Install (PICS) Km1210 1999 - 2003 7.3L Power Stroke Diesel 19 11-22-2013 07:27 PM
Let's See Your Interior!! Km1210 1999 - 2003 7.3L Power Stroke Diesel 54 07-16-2012 08:40 PM
I'm New here! 65Ranger 1973 - 1979 F-100 & Larger F-Series Trucks 12 02-27-2012 07:59 AM
Added one more to the family... yamaweezle Iowa Chapter 5 12-14-2009 07:38 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
