my 1977 F150 4x4 build... how we do it down under
#61
Just ordered my what should be the last parts I'll be needing for a while, at this point in the build anyway.
From Broncograveyard.com I ordered;
Warn premium lockouts
4340 Cro-mo axle set
Heavy duty headlight harness
Flex-a-lite fan
Believe it or not, its worked out about 50% cheaper for me getting all these parts from the USA, even after you factor in freight costs than it is buying from retailers here in Australia. Go figure that one out!
Until all these new goodies arrive I'll be preparing my new cab for my cab swap which will be happening in the next six months also.
Flex-a-lite fan
#62
for shackle flip i take off the front mounted hanger and relocate to the rear while replacing front with a late 70's or early 80's rear hanger.
I have some pics in my build thread on pirate here.. http://www.pirate4x4.com/forum/ford/...ld-thread.html
#63
#64
So how long do you normally wait for an overseas delivery? I can't help but let the parent out in me in that I hope you're using savings and not racking up debt. Not my business I know, just hate to see someone's passion dulled by a ridiculous intrest rate. I'll shut-up now.
#65
#68
Wow, your truck is a beast! Looks great!
#69
#70
Got a few little things done on the old girl this weekend while I wait for my new parts to show up. Got the steering drag link cleaned up and painted. Surprisingly, the ball joints either end are moving pretty well, so i hit it with a couple of coats of RustGuard hammered finish grey. I've found that the RustGuard gives an awesome looking finish to any crappy old piece of truck undercarriage with not much more than some degreaser and some wire brushing.
Got the front brake lines installed and made up a new bracket for it that hangs off what is now the diff breather spigot. Again, hammer finish grey is your friend
While i had nothing to, I made a new battery hold down out of diamond plate aluminium (I literally have s**t tons of it) in two layers that i riveted together to give it some rigidity... the old plastic one broke when I trod on it the other week :/
Before anyone says anything, I KNOW the wiring looks like an abomination, but its still better than when I first bought the truck. I have been working on it slowly, and will fully see to it once and for all when i do the cab swap in the near future. My best friend is an electrician and had a good look at it all, and while its sure as hell not pretty, it is pretty safe.
#71
#73
73, looks good. Needs more diamond plate though lol. As my fabricating skills improve I'll likely be making similar stuff.
NW 150, thanks! I'm pretty sure its a 6" but I bought it 2nd hand so you never know. I did do some measuring before I installed it all and the new components were all 6" greater in length. Having said that, the 42"s have shrunken 3" and the fender chop has opened the arches up a lot... and its worth pointing out that in the pic on the first page, I'm not a tall guy lol.
#74
You said your ordering chromoly axles?
Man I just got back from wheeling all day and I shattered a d60 front axle joint(basically new spicer) and a long side inner shaft.
I was hammering down hard on a gnarly rock face with air locker on and 44's smoking. Even d60 stuff breaks.
I'm upgrading inner axles to chromoly as well with better ujoints either Yukon super joints or ctm's
