Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 12-29-2012, 11:34 PM
jjurva! jjurva! is offline
Garage is empty, add now
jjurva! is starting off with a positive reputation.
Rear end parts for 1960 9 inch rear end
I am missing one of the plates that sits on top of the leaf springs and under the u bolts. Napa doesn't sell parts like this anymore. What is the part called? Can I just get one that has the same dimensions that is for a newer truck? Also where can I get U bolts for this truck? It is a f100 4x4 so they have to be pretty long. Any help is appreciated.
  #2 (permalink)
Old 12-30-2012, 07:41 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
2013 Ford Escape
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Rear end parts for a 1960 F100 4WD 9" rear end.
Quote:
Originally Posted by jjurva! View Post
I am missing one of the plates (caps) that sits on top of the leaf springs and under the u bolts. What is the part called?
Also where can I get U bolts for this truck? It is a F100 4x4 so they have to be pretty long.
B9D-5796-A (replaced B7C-5796-A & B9TT-5796-A) .. Rear Spring Cap ~ Located on top of rear spring, u-bolt threads pass thru it / Obsolete
1957/64 F100/250 2WD & 1959/64 F100/250 4WD
No Ford Dealer or obsolete parts vendor has any.
B7C-5705-A .. U Bolt / Obsolete
1957/60 F100 2WD = Use with 7 or 9 leaf spring pack / 1959/60 F100 4WD = Use with 7 leaf spring pack only.
CARPENTER NOS PARTS in Concord NC has 3 = 800-476-9653.
NORTZ & VIRKLER FORD in Lowville NY has 5 = 315-376-6594.
B9C-5705-B .. U Bolt / Obsolete
1959/60 F100 4WD = Use with 9 leaf spring pack.
BOWMAN SALES & SERVICE in Bowman ND has 7 = 701-523-3257.
Note: 4WD's use different 7 & 9 leaf rear springs than 2WD's.
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
2013 Escape SE FWD 2.0L Eco-Boost.
  #3 (permalink)
Old 12-30-2012, 10:29 AM
willowbilly3 willowbilly3 is offline
willowbilly3 is gaining momentum as a positive member of FTE.
Any spring shop can make u-bolts. Maybe take the other plate off and just make one from some 1/2 inch plate.
  #4 (permalink)
Old 12-30-2012, 11:10 AM
Thanks guys! I will look into having some U bolts made if it is cheaper then buying them from a parts guy and making a spring cap doesn't seem like it would be too difficult.
  #5 (permalink)
Old 12-30-2012, 05:48 PM
You also might try a trailer supply store for the U bolts. I just went up to a local trailer dealerships parts dept for some U bolts a couple weeks ago and they had a whole wall full of them.
  #6 (permalink)
Old 12-30-2012, 05:51 PM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a good reputation on FTE.spurredon has a good reputation on FTE.
Speedway sells the ubolts. Here's the link. Pretty reasonable actually! Speedway 1948-60 Ford Half-Ton Rear Axle U-Bolts, Set/4 - Speedway Motors, America's Oldest Speed Shop
  #7 (permalink)
Old 12-30-2012, 11:01 PM
Yeah! That seems like a pretty good price. I'm not sure if they are long enough though. I will have to go measure. Thanks!
  #8 (permalink)
Old 01-08-2013, 09:46 PM
Hi, so I measured and those ones are too short. The ones I have are 12" long. I think I will just have a company bend some or try to save the ones I have.
Tags
axle, bracket, rear end, u bolt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
