weathertech bug guard and vent visors
Installed the weather tech bug guard and vent visors today! Looks sweet! Not sure about how far the bug guard sticks up, not very low profile! I'll give it a week. The vent visors however, are prefect! Also did the front floor mats,i had the fomoco all weather ones. Not enough
You do have some adjustment you can do on the grill, there's 4 bolts on top you can loosen to adjust the grill in and out. I see you're from Montana, what part ? I'm from Billings. Have you been to the Montana chapter of this forum yet found here: Montana Chapter - Ford Truck Enthusiasts Forums
Thanks for the pix. I see your floor mats do overlap the threshold. On their website, they don't quite reach the threshold. We have a truck at work with similar floor mats and the edge by the threshold is about two inches tall. What a tripping hazard! I'm glad to see these are not like that. Hope you didn't get wet taking the pix. Thanks again.
Those vent visors look good. Do they do a good job of keeping the washer fluid off of the side windows when you wash the windshield? It's very annoying to get a water stream on the side windows when you try to wash off your windshield.
I have the weathertech floor mats and I have to say the fit/finish is much better than the huskies I had in my F150.
Did weathertech add the adhesive to the side window deflectors?
I have the WT side deflectors but early on in 2010 they didn't have the adhesive so they flop around in the channel when the windows are down.
I had WT side deflectors on two Explorers and they had adhesive.
I also have the WT hood deflector and you're correct, it does stick up but I like it.
