Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > 6.2L V8
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8 SPONSORED BY:
  #1 (permalink)
Old 12-29-2012, 09:51 PM
Snowman 8 Snowman 8 is offline
Garage is empty, add now
Snowman 8 is starting off with a positive reputation.
Super Duty 6.2 only 385hp?
Anyone know why the geniuses at Ford de-tuned the 6.2 in the super duties to 385hp and 405ftlb of torque when the 6.2 in the F150's are rated at 411hp and 434ftlb of torque. Why would they de-tune an engine in a heavier truck that will be pulling and hauling heavier loads?
  #2 (permalink)
Old 12-30-2012, 05:31 AM
senix's Avatar
senix senix is offline
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
Because it is towing and hauling heavier loads..and you will be pushing the motor harder more often then a F150 would.
__________________
http://www.ford-trucks.com/forums/pi...ctureid=114550
Scott-2008 F250 PSD Crew Cab 4x4, 12K GVWR,
Cooper Discovery STT LT275/70R18's
Banks Ram Air & 6-Gun, Ravelco Alarm System, Frontier Extreme FT. Bumper
2013 40' 4-slider stoneridge 5th wheel coming in at 15,400
http://www.ford-trucks.com/guidelines.html
  #3 (permalink)
Old 12-30-2012, 09:42 AM
Slowpoke Slim's Avatar
Slowpoke Slim Slowpoke Slim is offline
2012 Ford F-250
Slowpoke Slim is gaining momentum as a positive member of FTE.
Plus I believe the power curves on the 150 are higher up in the rpm band. The SD 6.2 makes like 80% of it's power at 1000 rpms, and 90% of it's power at 2000 rpms. That's real power that you can use.
I have one and love it, you should drive one. Nice combo of power, and trans gears and shift points.
  #4 (permalink)
Old 12-30-2012, 01:39 PM
I have one, I have a 12 F350 and it feels under powered! I guess it is what it is because we don't have another gas engine to choose from but my wife's F150 with the 5.0 will run circles around this truck. There is no reason to de-tune an engine because it is in a larger truck, it just forces you to run the engine harder rather than being able to back of a little bit because you have the extra power. Coming from a 6.0H NO it is nice not to have to put thousands of $ a year to keep it running!
  #5 (permalink)
Old 01-01-2013, 02:27 AM
03 SVT VERT 03 SVT VERT is offline
03 SVT VERT is gaining momentum as a positive member of FTE.03 SVT VERT is gaining momentum as a positive member of FTE.
Quote:
Sounds about right. On average a half-ton weighs a good 500 to 1000lbs less than a similar configuration 1-ton. That typically gives it a better power to weight ratio, even with an engine that has significantly less hp (like the 5.0L's 360hp vs the 1-tons 385hp).
With that in mind, even with a lower power to weight ratio, the Heavy Duty truck will still tow and haul circles around the light duty truck when the load gets heavy. They're totally different animals designed with a totally different duty cycle in mind. Hence the 6.2L's being tuned differently in the light duty trucks vs. the heavy trucks.
  #6 (permalink)
Old 01-01-2013, 08:31 AM
Front Runner's Avatar
Front Runner Front Runner is offline
2002 Ford Excursion
Front Runner has a superb reputationFront Runner has a superb reputationFront Runner has a superb reputationFront Runner has a superb reputationFront Runner has a superb reputationFront Runner has a superb reputationFront Runner has a superb reputationFront Runner has a superb reputationFront Runner has a superb reputationFront Runner has a superb reputationFront Runner has a superb reputation
The powerband of the 6.2 is higher in the rpm range also. I think you have the power percentages of the 6.2 confused with the 6.7 diesel.
__________________
2002 Excursion Limited, 4x4, V10, 4.88 gears, 6" PC lift , 20" XD Hoss wheels, 35" Pro Comp tires
2013 VW GTI 2.0L TSI, 6 speed Manual
  #7 (permalink)
Old 01-04-2013, 09:26 PM
Jettix2's Avatar
Jettix2 Jettix2 is offline
Jettix2 is starting off with a positive reputation.
I read the 6.2 in the super duty has a different camshaft than the 150 and is designed to reduce knock / detonation under heavy, sustained towing....hence the slightly lower power figures.
__________________
2011 F250 Crew Cab Lariat 4WD 6.2L w/ 3.73 , Factory 20's w/ Firestone Destination ATs, AAL + Sway Bar, 5-Star Tuned!
  #8 (permalink)
Old 01-05-2013, 06:41 AM
2000silverbullet's Avatar
2000silverbullet 2000silverbullet is offline
2011 Ford F-350
2000silverbullet is a name known to all2000silverbullet is a name known to all2000silverbullet is a name known to all2000silverbullet is a name known to all2000silverbullet is a name known to all2000silverbullet is a name known to all
Also remember the hp rating of the 6.2 in the F150 is rated on 91 octane while the 6.2 in the SD is rated on 87. 87 in the F150 6.2 drops it to 401 while 91 in the SD 6.2 brings it up to probably close to 395...
You will see an increase in hp just running a higher octane on the 6.2. Jettix2 is correct, the SD and F150 do have different cams.
__________________
Matt
2011 F350 - 6.2 CC, LB, 4.30s, Lariat Ultimate pkg, FX4, Amp steps, Lockpick, AC LC6i, JL HD900/5, JL 13TW5, JL C5-570's, Bilstein 7100 stabilizer, Rancho RS9000XL's, Leveled w/ 35" Toyo M/T's and 5 Star tuned
**Sold - 2000 F250 V10, 6.5" Pro Comp, 37" Toyo MT's
  #9 (permalink)
Old 01-05-2013, 09:00 AM
I see what your saying about running 91 octane but that gets kinda spendy for a daily driver that only gets 10mpg.
  #10 (permalink)
Old 01-05-2013, 11:40 AM
2011 Ford F-350
True, but my point was that the hp is so close between the 2 motors that it's almost negligible... I doubt most would feel the 16hp/~20ft lb's tq difference (difference between the two on 87 octane).
__________________
Matt
  #11 (permalink)
Old 01-09-2013, 08:47 AM
unyalli's Avatar
unyalli unyalli is offline
2012 Ford F-250
unyalli is starting off with a positive reputation.
I'd like to add some observasions if I may. With winter here and fuel mielage down I'm at the bottom of the 13mpg range. For grins I did 92 octaine the last three tanks and am now mid to upper 13's. I usually fill at half and it's around 20 gallons. There is a 10 cent difference from 88 octaine midgrade and 92 so 2 bucks a fill up. Two bucks in this day is pennys.
Are you guy's sure the power goes up with better than 87 octaine? Mileage did so I'm wanting to believe this is true.
If this is true I garantee I'll be towing the camper this summer with premium. A trip out to Vedauwoo and back won't cost me a 12 pak difference.
__________________
Some say extreme scientific attention to detail... others say **** retentive.
2012 F250 Lariat 4x4 CC LB Boss 379 3.73's
  #12 (permalink)
Old 01-09-2013, 10:45 AM
2011 Ford F-350
It's definitely true, that came from the 6.2 chief engineer (Mike Harrison) who was here a couple years back when the 6.2 was introduced.
Here's the post:
http://www.ford-trucks.com/forums/92...ml#post8833938
You oughta see what the truck does on 93 with a tune on it.
__________________
Matt
  #13 (permalink)
Old 01-16-2013, 08:56 PM
builtftough4.6 builtftough4.6 is offline
builtftough4.6 is starting off with a positive reputation.
some quality info man,thx for the link! just hit 10,000 miles the other day and Ive ran nothing but 93 through that boss motor
Quote:
yea pretty sure WOT is 4200 RPMS on our trucks,gona be your 90% reeling 100 in at 5500-ish.
  #14 (permalink)
Old 01-16-2013, 08:59 PM
unyalli - maybe it makes sense man ,I read 13.5 on the dash on 93 not towing
do a MPG formula on a full tank 87 , then compare it to 93 man. I would I wont let that cheap ethanol trash around these parts touch my injectors tho.not running corn oil through alaskan pipeline bros . lol
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
