9" leafs fit dana 60 rear?
Old 05-26-2003, 11:37 AM
fiend's Avatar
fiend
fiend is offline
Would a 6" lift kit for a 78 Bronco fit a dana 60 rear that's been put in the Bronco?
Also i'd be putting a 8 lug Dana 44 in the Bronco. The 8 lug as you all know uses leaf springs, i'd rather use coils as they are cheaper. What kind of process would it involve changing over the Dana 44 from leafs to coils?
Old 05-26-2003, 02:36 PM
77'F-150Mudder's Avatar
77'F-150Mudder
77'F-150Mudder is offline
Yes your 6" lift will fit the Dana 60 as long as it's equipped with spring perches for 3" wide leafs. If it doesn't have the right perches, new ones can be easily welded on by an experinced welder.
To bolt the HD D44 in up front you will need to have c-bushing mounts welded to the diff. Otherwise it's pretty much a bolt n' go operation.
Old 05-26-2003, 02:50 PM
RRMike's Avatar
RRMike
RRMike is offline
Does the bronco have a front end in it now? If it does I think you can just swap the spindles and hubs to the hd 8 lug stuff. Then you won't have to do any fab work.
Old 05-26-2003, 03:02 PM
77'F-150Mudder
Good point.
Old 05-26-2003, 03:33 PM
fiend's Avatar
fiend
fiend is offline
It has the stock D44 up front.
Wouldn't the F250's D44 be stronger than the Bronco's though?
Old 05-26-2003, 05:51 PM
RRMike's Avatar
RRMike
RRMike is offline
No. From the ball joints in it's the same I think.
Old 05-26-2003, 06:30 PM
77'F-150Mudder
Yeah, I think rrmike is right. Try a search on "HD Dana 44". This has been discussed several times.
fishindave11
1978 - 1996 Big Bronco
06-15-2012 04:21 AM
immastrokinnow
Offroad & 4x4
08-10-2011 11:35 AM
'79 fourdoor
11-02-2010 01:01 PM
OrFordGuy
03-05-2009 06:36 AM
Broke_Okie
Offroad & 4x4
05-24-2007 09:51 PM
Quick Reply: 9" leafs fit dana 60 rear?
