GUYS GUY LOOK QUICK SWEEEEEEETTTT
CHECK THIS OUT I JUST CAME ACROSS THIS A COUPLE OF DAYS AGO AND I CUT MY MUSTANG 2 IFS OFF AND ORDERED ME ONE OF THESE
ALSO I WAS WANDERING IF ANYONE OUT THERE HAS USED THE TRANSMISSION FROM THE CROWN VIC THIS WAS MY ORIGINAL QUESTION DOESNT IT USE THE COMPUTER TO SHIFT ??? IF SO IS THERE A WAY TO HOOK JUST THE COMPUTER UP SO JUST THE TRANNY WILL WORK ? OR IS THERE A COMPANY THAT HAS A SMALL COMPUTER THAT WILL RUN THE TRANNY OR ???????? PLEASE LET ME KNOW WHAT YOU GUYS THINK THANK YOU
Old news for my area. My uncle has built 3 now.(and there were already several around) 1967-73 you can use the whole Crown Vic rails, 1974-79 they use Towncar rails. The 4.6L cars without keyless entry are the easiest to make run. I'm going to use the Crown Vic cross member on my 55 with a 4.6L DOHC (I think).
The positive offset wheel you're seeing has a mounting surface about 2 1/2 - 3" inside that flat hub cap.
It seems there's more fab work than I thought. I understood the crown vic to be an easy bolt in. I only watched the video once, and I may have missed something, but it seems there were alot of add on's to the frame to make it work. Of course, this is opinion is from a Jag ifs owner. Drill some holes, make a shock mount, done.
The problem is you're comparing wheel track where if you wanted to have a more accurate comparison, they should be compared at the wheel mounting surface on the hub.
Look at 5:16 in the video, it shows a wheel in the box. Those wheels are aluminum, don't have hubcaps and you can easily see how much pos offset they have.
From wikipedia about the engineering changes for the 2005 GM:
The new suspension changes required changing wheel designs to those with a high positive offset.
All I'm saying is if you're going to compare things, please compare apples to apples. Put the stock F-100 wheels and tires on the Crown Vic and see what the track width would be in relation to the OEM application. Of course, if you move the wheel mounting surface further outward, you can make up the difference to keep everything under the fenders by using a positive offset wheel. There's noting wrong with that. Also understand the turning arc of the spindles will be different to accommodate the wheel designed for each application. There's a lot of things to consider when doing front suspension swaps, not just wheel track.
The wheel pictured above has an indentation deep enough to fit lug studs and nuts inside with room to spare, and the wheel mounting flange is about an inch thick.
