having starting issue
the last couple days when I start my truck the starter keeps running even if I turn off the key. first time it happened I turned key back to run and it started and the starter disengaged. today I had to disconnect the battery cable to stop it. first I tried disconnecting the small wire going to the fender mounted solenoid it didn't stop till I disconnected the battery cable. don't have any idea what it could be.
Is this on your 1995 F-350? First time I heard of this happening on a 1992 or newer. One of your solenoids must be sticking. The fender mounted one or the one on top of the starter. Next time it sticks trying tapping on the fender mounted solenoid to try and release it. About the only cure would be to replace the sticking solenoid.
Received 3,090 Likes
on
Yhoa, I would try the fender mounted solenoid first, beings it is a lot easier to replace. If it sticks any more before you get it replaced, try giving it some karate chops or tap on it in some manner. This will usually always release a sticking fender mounted solenoid. Keep us posted so we know for sure what it was.
on
well took starter off and took it in to be checked, it tested bad, but the ring gear on the flywheel is toast also. so I am going to have to pull it apart (again for those who followed my build thread) and replace the ring gear again. truck aint got 2000 miles on it since rebuild. this bites
92f350noob
06-30-2019 06:40 PM
dkaiser1963
02-17-2008 11:12 PM
Kitester
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
04-03-2005 08:36 PM
