Another 97 CC build thread
Old 01-26-2013, 08:14 AM
nateairman's Avatar
nateairman
nateairman is offline
The f150 had been sitting in a yard for a few years and I have been going through it. I was chasing a cooling issue that led to most pieces being replaced. I found the water pump missing half the impellers and the rest were wrapped around so that it was still balanced! Maybe it was started with ice in the pump? Never have seen that before.
  #32
Old 01-26-2013, 10:44 PM
oldbird1965's Avatar
oldbird1965
oldbird1965 is offline
I never have! Ice sank the Titanic though.
  #33
Old 01-27-2013, 09:42 AM
nateairman's Avatar
nateairman
Here are some photos. Took a lot of work to get the fan off. Made a custom wrench.
http://i1174.photobucket.com/albums/...AE0FC372CD.jpg
  #34
Old 01-27-2013, 01:35 PM
nateairman's Avatar
nateairman
The new wheels and tires:
Should I powder coat them black?
  #35
Old 01-27-2013, 03:51 PM
427 fordman's Avatar
427 fordman
427 fordman is offline
I'd leave them alone. They look nice and to be in good shape.
  #36
Old 01-29-2013, 12:21 PM
nateairman's Avatar
nateairman
Here is a photo of the two trucks:
I thought of taking the doors fenders and other pieces from the 150 and putting them on the 350. The 150 will be the dd while the diesel is in the shop.
  #37
Old 01-29-2013, 02:56 PM
427 fordman
Are they the same color? Looks like it, but its hard to tell for sure, picture is kinda dark.
  #38
Old 01-29-2013, 08:03 PM
nateairman's Avatar
nateairman
Yeah I think so. I have to look at the paint codes to be sure. Oddly both trucks have a crease at the bottom of the doors even though the 150 is a 95. I believe the paint code for the 150 is wb and the 350 is nb... I'll have to look to be sure.
  #39
Old 02-10-2013, 09:30 AM
nateairman's Avatar
nateairman
I have finished fixing all the springs in the front bench. What a difference! It is good.
I am going to pull the drive lines and send them in for a rebuild and balance. Has any one used this traction bar? At 1040$ it seems steep but it looks like a good solution.
http://www.pmfsuspension.com/Fabrica...Block_p_9.html
I will be doing rear axle bearings next. Any suggestions or tips?
  #40
Old 02-10-2013, 01:24 PM
427 fordman
Timken bearings is all I use. No real tips though. As far as the traction bars, a grand is a lot for something that can be made fairly easy. JMO of course.
  #41
Old 02-10-2013, 03:23 PM
nateairman's Avatar
nateairman
Looks like I will be welding dome exhaust next. The road salt has done a lot of damage this year!
  #42
Old 02-17-2013, 02:48 PM
nateairman's Avatar
nateairman
It seems that I am collecting these trucks now! A friend has been bitten by the new truck bug and is selling his truck. He was going to trade it in but I offered to trade him for the f150 and some cash. I hope he takes it!
  #43
Old 03-23-2013, 03:24 PM
nateairman's Avatar
nateairman
I look forward to getting all the parts I have ordered over the last couple of months! I have a lot of work to do when the box is off. The cracked frame is getting welded and fish plated as well as replacing shackle and shock mounts. I don't have much room here so the parts have been collecting at a friends place and we will plan to take it all apart and install everything we can in a few days.
I bought some oem dodge mirrors to install with power and heat has anyone installed these? Did you use the factory switch? I have an xl so I will be installing my own wiring system but would like to know what others have done. Currently I am going to use the stock dodge swith mounted in the top of the door panel near the vent window....
I have a few door panels to mess with as well as extra doors so I am not too worried about the first time being perfect.
I have a set of four electric door lock actuators that I will be installing with an alarm system and am wondering where the xlt's had the power sent into the rear doors
  #44
Old 03-23-2013, 11:39 PM
ReBilld's Avatar
ReBilld
ReBilld is offline
Got ant pics? Sounds like a good build!
  #45
Old 03-27-2013, 07:41 PM
nateairman's Avatar
nateairman
What would you like photos of? Seems like I am working on both ends and still driving it!
Quick Reply: Another 97 CC build thread
