Speedometer Cable, Newer Transmission, OEM Gauges
Hello,
As I progress in my 52' Ford F1 restoration I have noticed something that may be sort of a problem for me and I was wandering what some of you may have done in a similar situation.
I have replaced the old 3 speed transmission with a newer 5 Speed M5r2 from a 1990 Ford pickup. What type, how, or is it possible to get a speedometer cable that will hook up to this newer transmission that will be compatible with my original gauges? I have found some reproduction gauges I/e Doc's Kustom Gauges, that I have considered buying, but my wife is fond of the original gauges.
So, is it possible to do this? Or what have some of you guys done on this type of Restoration?
Thanks again guys! Without your help my efforts would be very, very limited!
Jon Preston
1952 Ford F1
302 with 5 Speed M5r2
Jon Preston
1952 Ford F1
Hello,
Jon Preston
1952 Ford F1
Jon Preston
1952 Ford F1
I used the same cable that was in the mid 80s pickup I robbed the drivetrain from.
I had my wife follow me down the road just to see how far off it was and as it turned out it was within 5 or 7 miles an hour which I just kept in mind and adjusted my driving habits with.
I know it seems hard to believe that this would have worked at all but it did.
I'll do some research and try to find a few places that offer the cables. I used to own a 1972 Duster that the speedometer read about 5 mph different, so I always carried an extra speedometer cable in the backseat for the alibi of "I just got a new cable officer and I'm gonna fix it...."
Thank you guys very much and I greatly appreciate all of the help!!
Merry Christmas!
Thanks again,
Jon Preston
Merry Christmas!
Thanks again,
Jon Preston
Assuming your new transmission still uses a driven cable system (many new ones are electronic), you can generally get a different driven gear in the trans to change the speedo ratio if your speedo is off. As said earlier, most of the cables themselves are just a square drive that has been used for years, it is generally the length and ends that are different. A quick trip to NAPA with the ends that you need may be a good possibility.
Hello Jon, prob. does not help but my first go around with my F-7 I put a 302 automatic in it.
I used a universal cable from Summit Racing. It has the 5/8 end for the mechanical speedo, and I was able to find a Ford version for the transmission end. There are a bunch of sites if you search to figure out which drive gear to use based on tire size and rear-end gear ratio.
It was something like this part: Lokar Speedometer Cables SP1502U - SummitRacing.com
I also found an app for my iphone called justspeed. It is a GPS speedometer. It is pretty accurate if you can hold it at a constant speed. It's not so good if you are changing speeds.
Some speedos have a 3/4" fitting, so check to see what you have.
Dan
Dan
I have the same proplem.My AOD has the 2 wire sensor in the trans.I have played around with it and have found that you can take the white cap off the end of it and inside there is still a square drive shaft that a cable will go into.The original cable will not fit inside because the end is to big.I am going to grind it down to a smaller diameter the silicone or eboxy it together.Should work.
Don52M3
08-31-2018 06:23 AM
jmfsms
06-18-2015 04:52 AM
ShamelessMT
06-25-2009 02:55 PM
