help hiding wiring - Ford Truck Enthusiasts Forums
help hiding wiring
Old 12-29-2012, 01:25 AM
heartlandcowboy90 heartlandcowboy90 is offline
heartlandcowboy90 is starting off with a positive reputation.
help hiding wiring
Hi all, I am about to install my first system but I dont know how to hide the wiring. Everything ive read says to hide it under the carpet but what if you dont have carpet? i have a 90 f150 and it has the plain jane vinyl flooring. How can I make my installation look clean and professional?
Old 12-29-2012, 07:26 AM
2000silverbullet's Avatar
2000silverbullet 2000silverbullet is offline
2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold
What's it look like under the vinyl? I'd imagine there's a pad of some sort under there that you could tuck the wires into.
Old 12-29-2012, 09:59 AM
dee004's Avatar
dee004 dee004 is offline
dee004 has a brilliant futuredee004 has a brilliant futuredee004 has a brilliant futuredee004 has a brilliant futuredee004 has a brilliant futuredee004 has a brilliant futuredee004 has a brilliant futuredee004 has a brilliant futuredee004 has a brilliant futuredee004 has a brilliant futuredee004 has a brilliant future
Like Matt pointed out there should be some type of insulation under the mat. You can run it down there. I've fished it under the mat beside the tunnel to the back which keeps it out of the way of wet boots etc.
Old 12-29-2012, 04:12 PM
running wires
I think ive figured out how to hide them,the door sills at the bottom. Is there a free hole in the firewall to run my 4 gauge power wire through or will i have to drill one?
Old 01-03-2013, 06:26 AM
JWA's Avatar
JWA JWA is offline
JWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputation
Most likely you'll have to drill a hole especially since you're running a 4ga wire. I've done this for 10 or 12 gauge and always use a rubber grommet to prevent chafing or cut insulation.
Old 01-03-2013, 07:53 AM
dee004's Avatar
If your truck is auto you can run through the large grommet where the clutch rod would've been installed.
bronco rear window wiring gpence 1978 - 1996 Big Bronco 1 03-21-2013 07:54 PM
refurb cab interior - molded carpets, etc bithead08 1994.5 - 1997 7.3L Power Stroke Diesel 5 03-18-2013 09:34 AM
Help! how to hook up an Electric seat into a 1983 F100 drewduncan15 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 9 12-18-2011 09:38 PM
Ear on good music 1vasnowman Electrical Systems/Wiring 1 04-14-2007 09:19 PM
Saddam replies to Dubya. Mil1ion General NON-Automotive Conversation 0 04-04-2003 09:48 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
