2003 Harley F150 Factory Alarm System has rendered truck un-startable
I left my keys in my girlfriends car and used my spare, probably for the first time ever to try to start my truck.
Upon turning the ignition over, the alarm starts going ape ****. I didn't have the fob so the only way to turn it off was to unplug the battery.
I got the key fob and primary key I use to start the truck this morning and hooked the batter back up and turned the ignition, same result.
Except this time, I can get the horn to stop blaring because I have the fob.
Problem is, I cannot get my truck started.
1) I've seen lots of people posting about this ****ty alarm system (on my 9 year old truck no less) not working correctly, but no solutions. What can be done to resolve this problem?
The ford dealership says I may need to tow it 30 miles in to the dealership for them to re-set something. That sounds absurd.
2) Longer term, is there a way to completely disable the alarm? I don't need it and don't want it. From time to time when pumping gas it does this, but I usually can lock the car and then open the car door by sticking the key in the door, thereby indicating to the alarm system that I am indeed the owner and then it starts.
Please help!!!!
PS Thank you ford for an awesome truck but no thank you for a ****ty alarm product. When you keep the owner of the car with the official key from starting his own danged vehicle, you haven't quite hit the mark.
Please help!!!!
baylor3217
1997 - 2003 F150
04-04-2013 04:31 PM
Battman76
Escape & Escape Hybrid
05-01-2011 12:30 PM
VTfordf150
1999 to 2016 Super Duty
04-24-2010 01:23 AM
