2003 Harley F150 Factory Alarm System has rendered truck un-startable - Ford Truck Enthusiasts Forums
Old 12-28-2012, 01:16 PM
baylor3217 baylor3217 is offline
baylor3217 is starting off with a positive reputation.
I left my keys in my girlfriends car and used my spare, probably for the first time ever to try to start my truck.
Upon turning the ignition over, the alarm starts going ape ****. I didn't have the fob so the only way to turn it off was to unplug the battery.
I got the key fob and primary key I use to start the truck this morning and hooked the batter back up and turned the ignition, same result.
Except this time, I can get the horn to stop blaring because I have the fob.
Problem is, I cannot get my truck started.
1) I've seen lots of people posting about this ****ty alarm system (on my 9 year old truck no less) not working correctly, but no solutions. What can be done to resolve this problem?
The ford dealership says I may need to tow it 30 miles in to the dealership for them to re-set something. That sounds absurd.
2) Longer term, is there a way to completely disable the alarm? I don't need it and don't want it. From time to time when pumping gas it does this, but I usually can lock the car and then open the car door by sticking the key in the door, thereby indicating to the alarm system that I am indeed the owner and then it starts.
Please help!!!!
PS Thank you ford for an awesome truck but no thank you for a ****ty alarm product. When you keep the owner of the car with the official key from starting his own danged vehicle, you haven't quite hit the mark.
Old 12-31-2012, 11:03 PM
fmerkl fmerkl is offline
fmerkl is starting off with a positive reputation.
Guess it say's you don't own the truck!! the tow is cheap insurance that you not trying to steal my truck!
Frank
Old 01-01-2013, 07:15 AM
enriched&beyound's Avatar
enriched&beyound enriched&beyound is offline
enriched&beyound is starting off with a positive reputation.
Please help!!!!
Like all things...it is great when it is working correctly, not so much when it is not.
most likely, yes the "PATS" system it needs to be reprogrammed. and dealer is the better place.
other things to check is to make sure your battery is good. Improper voltage can really mess with the electrical's Also make sure the relays and fused are all good.
do have a after market remote starter??
Old 01-01-2013, 11:56 AM
Lime1GT Lime1GT is offline
Lime1GT is starting off with a positive reputation.
Did you try starting it with the back-up key again?
Old 01-01-2013, 12:11 PM
RLGJ RLGJ is offline
RLGJ is starting off with a positive reputation.
I have had mine alarm a few times and had to use remote to lock and unlock it to get it to stop but never had issue with it starting.
Old 01-02-2013, 05:15 PM
Six Feet Under Six Feet Under is offline
Six Feet Under is starting off with a positive reputation.
My truck is acting weird as well, just slightly different symptoms. I have a 2003 F-150 XL and occasionally the entire dash (theft, service engine soon, low fuel, battery, and oil/coolant lights) will flash rapidly when I turn the key to ON. If this happens, the truck will NOT start. A couple of times, pressing the trip odometer reset button will make the dash stop flashing and allow the truck to start.
Not sure if it's the anti-theft system or not, but I don't really feel like spending the money at the dealer on a "maybe" solution when it could be several different things. I have a bigger battery in there now and the truck hasn't acted weird since I changed the battery out (yet, anyways... I'm not holding my breath). The last one tested good at 12.41 volts but I never did a load test because I couldn't get it started to drive it to AutoZone... New battery has the correct cold cranking amps (650-700 vs. 500-550) so maybe that was causing something funky to happen, I don't know.
Old 01-03-2013, 05:27 AM
Quote:
Originally Posted by Six Feet Under View Post
My truck is acting weird as well, occasionally the entire dash (theft, service engine soon, low fuel, battery, and oil/coolant lights) will flash rapidly when I turn the key to ON.
yes..... that is what can happen when the battery is failing, gauges go crazy and what not. Most likely your old battery would have failed a load test. You have found your solution.
Just make sure that your battery cable & connections are in good condition.
Old 04-04-2013, 04:02 PM
Mikl Mikl is offline
Mikl is starting off with a positive reputation.
Hey Guys, I'm new here because you guessed it, got a problem. My 2003 F150 started not un locking the driver side door. Had to do it manually. Then yesterday it wouldn't start, just turned over and the theft light was blinking. There were no codes to clear but after I hooked up the code reader it started. later it did the same thing. The battery turns over fast as always but no fire. Any ideas? Thanks
Old 04-04-2013, 04:31 PM
SwOkcOffRoader's Avatar
SwOkcOffRoader SwOkcOffRoader is offline
SwOkcOffRoader has a good reputation on FTE.SwOkcOffRoader has a good reputation on FTE.
Mine does that if I jump in and turn the key too fast. I think the PATs system didn't get enought time to read the key before I hit start. But that's just a guess.
2003 Harley F150 Factory Alarm System has rendered truck un-startable baylor3217 Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 1 04-07-2013 07:31 PM
Ford Gold Alarm installed-First impressions TIKT B8 2007 - 2014 Expedition & Navigator 4 08-31-2010 10:20 AM
How to permanently disable alarm system? noyield Explorer, Sport Trac, Mountaineer & Aviator 1 10-07-2003 07:10 AM
Problem W/93 Explorer Factory Alarm CHADRINTX Explorer, Sport Trac, Mountaineer & Aviator 1 09-03-2003 12:55 PM
Disconnected battery - alarm problems lghtningstruk 1987 - 1996 F150 & Larger F-Series Trucks 3 07-13-2002 07:48 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
