7.3L Fuel Alt w/out adding tanks or parts?? - Ford Truck Enthusiasts Forums
Old 12-28-2012, 01:34 PM
babyheals babyheals is offline
babyheals is starting off with a positive reputation.
I am sick of spending 600+ a month on gas. I want to find a cheap alternative without having to add a seperate fuel tank or change all my fuel system parts. Since I work with Aircraft and use it in Naval diesel trucks, can my 2001 F250 7.3 run on JP8 Aircraft fuel and if so does it pose any cons? Will it ruin my truck over time?? Is it possible and what are the downsides??? Any help would be much appreciated.
Old 12-29-2012, 05:32 PM
binuya's Avatar
binuya binuya is offline
binuya has a great reputation on FTE.binuya has a great reputation on FTE.binuya has a great reputation on FTE.binuya has a great reputation on FTE.binuya has a great reputation on FTE.binuya has a great reputation on FTE.
My understanding is that JP8 doesn't have enough lubricity on its own. A friend who runs that or JetA, on occasion, will blend it with 5%-10% biodiesel. He's done just fine with that. Pretty strong smelling fuel though.
Old 12-29-2012, 06:57 PM
Would mixing regular diesel have the same affect as bio-diesel??
Old 12-29-2012, 07:46 PM
binuya's Avatar
Quote:
Probably not enough. Bear in mind that ever since ULSD replaced LSD, many people use lubricity additives to make up for the loss. Not that it is entirely necessary, in my opinion. Supposedly sufficient lubricity additives are added to ULSD to compensate for the reduced sulphur.
So if you blend with JP8, you're reducing lubricity in the ULSD which is already at minimum levels for the 7.3.
By adding just 2.5% biodiesel to ULSD, the increase in lubricity far exceeds any additive you can buy.
Auto meter 4310 and 4318 reading 190 ohms constant nogo73 Electrical Systems/Wiring 9 04-02-2016 02:24 PM
New to this site Not new to ford trucks Phil P SR New Member Introductions 0 02-06-2016 02:22 PM
SR-71 Blackbird -- The Greatest Plane Ever Made BassFantasizer General NON-Automotive Conversation 4 02-12-2015 06:55 PM
Oil pan & Tranny pan sealant? Pitcrw6 1999 - 2003 7.3L Power Stroke Diesel 2 12-09-2013 02:54 PM
playing it forward: 7/8" drain plug crush washer r_reed 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 12-02-2013 11:18 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
