new to f150's - Ford Truck Enthusiasts Forums
new to f150's
Old 12-28-2012, 07:48 AM
oilfield superduty oilfield superduty is offline
oilfield superduty is starting off with a positive reputation.
new to f150's
i'm about to buy a 2001 f150 supercrew 4x4 5.4l, has had full synthetic from day 1 and only has 115k miles. was curious if anyone knew of any problems i might be coming up on soon if there are any that happen this early in the trucks life.
Old 12-28-2012, 08:37 AM
IndyDragon IndyDragon is offline
IndyDragon is starting off with a positive reputation.
Not really. You're buying the same truck I drive and have no real issues. I aam going to have to put an IAC motor in it, but that's nothing major. I do occasionally have the PATS key problem but it's under warranty and really not a huge problem, more annoying at times. All in all, you're buying an awesome truck that will take anything you can throw at it while still being comfortable in a vehicle that looks great.
Old 12-28-2012, 09:24 AM
LucasMN's Avatar
LucasMN LucasMN is offline
LucasMN is starting off with a positive reputation.
Could need all 4 ball joints and/or tie rods if they are original.
If it hasn't had the plugs changed, it's probably time.
Old 12-28-2012, 09:35 AM
vaper vaper is offline
vaper is starting off with a positive reputation.
Check for engine noise on start up,make sure it is cold(Google 5.4 Triton engine noise) 2 valve,2001 has no cam phasers
Rust in the rocker panels and bottom sides of rad cradle supports,these are hard to see.
Broken exhaust manifold studs usually passenger side rear.
Spark plugs are know to come loose
Coil on plugs are known to fail when in OD,engine warm(egr open)feel for
miss when shifting into od. No code will be set.
That's all I can think of right now
good luck!
1997 F-150 4R70W 4X4 Transmission Question towmaster 1997 - 2003 F150 4 07-01-2015 03:15 PM
1999 f150 shift kit Bobbycolt 1997 - 2003 F150 1 09-28-2013 03:23 PM
Puchasing a 94 f150 xlt 4x4 avnmaintman 1987 - 1996 F150 & Larger F-Series Trucks 3 09-27-2012 08:11 AM
2006 F-150 4x4 Police Interceptor ghb2 2004 - 2008 F150 7 05-04-2011 05:43 PM
77 F-150 engine swap sgoffena 1973 - 1979 F-100 & Larger F-Series Trucks 4 04-24-2008 06:14 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
