Australia Chapter Join Chapter , Leader: ChunderDownUnder
New WW for Stock and 38R turbo
Old 12-28-2012, 02:32 AM
ChunderDownUnder's Avatar
ChunderDownUnder
ChunderDownUnder is offline
Some impressive results from the the new Wicked Wheel for the stock turbo
Radically Redesigned Wicked Wheel® makes 43 PSI on my STOCK turbo! - PowerStrokeArmy
And not as good as the stock but still impressive for the 38R
Wicked Wheel G2 for 38R Test Results - PowerStrokeArmy
Something to consider
Old 12-28-2012, 03:21 AM
aussie_f350's Avatar
aussie_f350
aussie_f350 is offline
Looks cool, can't wait for real world results
Old 12-28-2012, 06:12 PM
SSSimon's Avatar
SSSimon
SSSimon is offline
Brian, thanks for posting that! Really good stuff, the testing is fully scientific, so good to see a true before-after testing!
Have joined Power Stroke Army & now know what my next low-cost mod is, the WWgen2!
In fact, just ordered it off Diesel Site, now all I'll have to do is replace my 2.1 bar (35psi) boost guage which I'm just about topping out with my stock turbo with a 3 bar (45psi) one.
Old 12-29-2012, 04:46 PM
ChunderDownUnder
If I had my stock turbo I would be doing the same Simon. Its not the 42psi (although very nice) but more the added psi without over charging the turbo and those Back pressure #'s are awesome. You might want to look at getting your tunes changed as well. That extra charge could do with some more fuel. Just one thing to consider if you were to run at that PSI often is head studs and springs.
Old 12-29-2012, 08:27 PM
SSSimon's Avatar
SSSimon
SSSimon is offline
Thanks for that. I'll take that advice and NOT upgrade the injectors until I have done the head studs & springs!
BTW, I'm still just running the Superchips that the PO put on, pretty much permanently in the top tune with towing off. I'd like to go the Gearhead 6 pos tuner as the next mod once I get the Gen2 WW on. Other that that I am pretty happy with my truck's current truck set-up, i.e. stock HPOP & injectors - not really that keen on doing the heavy wrenching for the extra HP gains.
I like the idea of getting rid of the surge - they should call it 'pulsing' - with surge I was expecting to hear something like the wastegate going off under boost rather than that flutter at elevated boost which is obviously limiting the max throughput of air.
I've done a bit of reading on the GH site. I'm still not exactly sure what to ask for. I guess with free reburns getting the set up perfect at time of order is less of an issue. It would be nice to be able to download any necessary tweaks down the track.
Brian, have you had any adjustments done to the tunes that you're running, e.g. to change the trans shift points?
Old 12-31-2012, 02:35 AM
Nkelly's Avatar
Nkelly
Nkelly is offline
Farkall User
Very interesting....
Might get rid off my huge amounts of black smoke,cuz that's deff excess fuel..
Old 02-16-2013, 08:00 PM
aussie_f350
I think i would like to try one, been watching heaps you tube videos, read heaps and they are cheap really. But is the one Clay has;
Riffraff Diesel: Riffraff Diesel Billet WW Compressor Wheel 94-03
The same as the diesel site one;
http://www.dieselsite.com/wickedwhee...s-instock.aspx
If not what is the difference?
Old 02-16-2013, 08:22 PM
aussie_f350
then i found this and now i am real confused;
https://www.ford-trucks.com/forums/1...let-wheel.html
Old 02-17-2013, 12:43 PM
Jennifer at DS's Avatar
Jennifer at DS
Jennifer at DS is offline
The Wicked Wheel 2 is only available through DIESELSITE. It is custom designed and tested by us. There are of course other billet wheels available on the market. Just posting to help clear up any confusion there might be.
Old 02-17-2013, 02:36 PM
aussie_f350
Thanks, I know now the one I have been reading about so much is the dieselsite one. But the last link I posted has me unsure which one to get.
Old 02-17-2013, 04:17 PM
ChunderDownUnder
heard nothing but good about the dieselsite WW2 so I ordered one.
Old 02-18-2013, 02:44 AM
SSSimon's Avatar
SSSimon
SSSimon is offline
Fair enough too. I suspect that the other designs are just billet copies on the old anti-surge wheel.
Also, the implied criticisim on the DS wheel, re DS customers doing the testing, is probably the pretty much the same with all of these custom-made billet parts shops.
Leatherneck007
10-06-2014 08:07 PM
97-psd
15
10-20-2010 09:08 PM
Bowie
12-13-2008 11:50 AM
mxracer3276
11-13-2007 08:58 PM
Hiflyer746
10-05-2006 12:47 PM
Quick Reply: New WW for Stock and 38R turbo
