Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > International Region > Australia Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Australia Chapter Join Chapter , Leader: ChunderDownUnder
  #1 (permalink)
Old 12-28-2012, 02:32 AM
ChunderDownUnder's Avatar
ChunderDownUnder ChunderDownUnder is offline
Garage is empty, add now
ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.
New WW for Stock and 38R turbo
Some impressive results from the the new Wicked Wheel for the stock turbo
Radically Redesigned Wicked Wheel® makes 43 PSI on my STOCK turbo! - PowerStrokeArmy
And not as good as the stock but still impressive for the 38R
Wicked Wheel G2 for 38R Test Results - PowerStrokeArmy
Something to consider
__________________
Brian
03 F250 XLT LB . Full Engine build with all the goodies. Tuned by Matt
- cant wait until my motor blows so I can blame someone else -
join the Australian Chapter here-Join Chapter
  #2 (permalink)
Old 12-28-2012, 03:21 AM
aussie_f350's Avatar
aussie_f350 aussie_f350 is offline
aussie_f350 is gaining momentum as a positive member of FTE.aussie_f350 is gaining momentum as a positive member of FTE.
Looks cool, can't wait for real world results
__________________
Thanks
Andy
My build thread;
http://www.ford-trucks.com/forums/11...ck-thread.html
  #3 (permalink)
Old 12-28-2012, 06:12 PM
SSSimon SSSimon is offline
2005 Ford F-250
SSSimon is gaining momentum as a positive member of FTE.SSSimon is gaining momentum as a positive member of FTE.
Brian, thanks for posting that! Really good stuff, the testing is fully scientific, so good to see a true before-after testing!
Have joined Power Stroke Army & now know what my next low-cost mod is, the WWgen2!
In fact, just ordered it off Diesel Site, now all I'll have to do is replace my 2.1 bar (35psi) boost guage which I'm just about topping out with my stock turbo with a 3 bar (45psi) one.
__________________
Mods done: lots of cheap mods (Hutch, IC boots, plenum inserts, IH uppies, HPx, AIH delete, EBPV delete, hi flow outlet, CCV mod, OCR, Superchips, Zoodad, 6637, 4" TB exhaust, JW valvebody, coolant filter, FRx, '05 HD lights with switch bypass relays, B100 ready fuel system)
Mods NOT done: big oil, big brakes, big turbo
Next mods: ? tuner, G2WW (on the shelf), alloy diff covers
Australia: where Mechanics use spanners and Plumbers use wrenches...
  #4 (permalink)
Old 12-29-2012, 04:46 PM
If I had my stock turbo I would be doing the same Simon. Its not the 42psi (although very nice) but more the added psi without over charging the turbo and those Back pressure #'s are awesome. You might want to look at getting your tunes changed as well. That extra charge could do with some more fuel. Just one thing to consider if you were to run at that PSI often is head studs and springs.
__________________
Brian
  #5 (permalink)
Old 12-29-2012, 08:27 PM
2005 Ford F-250
Thanks for that. I'll take that advice and NOT upgrade the injectors until I have done the head studs & springs!
BTW, I'm still just running the Superchips that the PO put on, pretty much permanently in the top tune with towing off. I'd like to go the Gearhead 6 pos tuner as the next mod once I get the Gen2 WW on. Other that that I am pretty happy with my truck's current truck set-up, i.e. stock HPOP & injectors - not really that keen on doing the heavy wrenching for the extra HP gains.
I like the idea of getting rid of the surge - they should call it 'pulsing' - with surge I was expecting to hear something like the wastegate going off under boost rather than that flutter at elevated boost which is obviously limiting the max throughput of air.
I've done a bit of reading on the GH site. I'm still not exactly sure what to ask for. I guess with free reburns getting the set up perfect at time of order is less of an issue. It would be nice to be able to download any necessary tweaks down the track.
Brian, have you had any adjustments done to the tunes that you're running, e.g. to change the trans shift points?
__________________
  #6 (permalink)
Old 12-31-2012, 02:35 AM
Nkelly's Avatar
Nkelly Nkelly is offline
Nkelly is gaining momentum as a positive member of FTE.Nkelly is gaining momentum as a positive member of FTE.
Very interesting....
Might get rid off my huge amounts of black smoke,cuz that's deff excess fuel..
__________________
Bryan.
2005 FORD F250 7.3L, Maxxis BigHorns 35's,16x10 alloy rims,5"Procomp/Icon Vehicle Dynamics lift,AIH Delete,CCV,FRX,HPX, OCR,JW valve body,mag-hytec rear diff cover,wicked wheel,Garrett turbo outlet,F6 chip,Custom 4" to 5" exhaust,All from clay @ RiffRaff,BD big trans sump,Carpc got the ****,got a IPAD in the dash now
  #7 (permalink)
Old 02-16-2013, 08:00 PM
I think i would like to try one, been watching heaps you tube videos, read heaps and they are cheap really. But is the one Clay has;
Riffraff Diesel: Riffraff Diesel Billet WW Compressor Wheel 94-03
The same as the diesel site one;
http://www.dieselsite.com/wickedwhee...s-instock.aspx
If not what is the difference?
__________________
Thanks
Andy
My build thread;
  #8 (permalink)
Old 02-16-2013, 08:22 PM
then i found this and now i am real confused;
http://www.ford-trucks.com/forums/12...let-wheel.html
__________________
Thanks
Andy
My build thread;
  #9 (permalink)
Old 02-17-2013, 12:43 PM
Jennifer at DS Jennifer at DS is offline
Jennifer at DS is starting off with a positive reputation.
The Wicked Wheel 2 is only available through DIESELSITE. It is custom designed and tested by us. There are of course other billet wheels available on the market. Just posting to help clear up any confusion there might be.
  #10 (permalink)
Old 02-17-2013, 02:36 PM
Quote:
Thanks, I know now the one I have been reading about so much is the dieselsite one. But the last link I posted has me unsure which one to get.
__________________
Thanks
Andy
My build thread;
  #11 (permalink)
Old 02-17-2013, 04:17 PM
heard nothing but good about the dieselsite WW2 so I ordered one.
__________________
Brian
  #12 (permalink)
Old 02-18-2013, 02:44 AM
2005 Ford F-250
Fair enough too. I suspect that the other designs are just billet copies on the old anti-surge wheel.
Also, the implied criticisim on the DS wheel, re DS customers doing the testing, is probably the pretty much the same with all of these custom-made billet parts shops.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
