Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 12-27-2012, 07:58 PM
gorkah gorkah is offline
Garage is empty, add now
gorkah is starting off with a positive reputation.
AdvanceTrac traction control in lieu of snow tires or chains
Title pretty sums up my question. Do any expedition drivers here put in a lot of snow miles? I have a 2WD expedition with traction control EB edition.
We went up to the sierras the other day and CHP told us to put chains on because we weren't 4WD.
I was under the impression Advance TRAC should cover us.
Anyone else encounter any similar situations? Do you use chains on ur 2WD? Anyone with reliable performance experience with Advance Trac in the snow? Can I tell CHP to go to hell?
  #2 (permalink)
Old 12-27-2012, 09:48 PM
03 SVT VERT 03 SVT VERT is offline
03 SVT VERT is gaining momentum as a positive member of FTE.03 SVT VERT is gaining momentum as a positive member of FTE.
AdvanceTrac helps, but it's a reactive system. It sees that something isn't right and then tries to correct it (albeit very quickly). Depending on the problem it may or may not be able to correct accordingly.
Things like dedicated snow tires, tire chains, and 4x4 (when activated in advance) are proactive. It's only after they fail that a reactive system, like AdvanceTrac, would take over.
Essentially, AdvanceTrac is no substitute for tire chains. Even with 4wd it's a good idea to use dedicated snow tires or tire chains when the conditions call for it. They'll do more for your safety than both 4wd and AdvanceTrac ever will.
  #3 (permalink)
Old 01-02-2013, 11:09 AM
gpfarrell gpfarrell is offline
gpfarrell is starting off with a positive reputation.
My 4wd Navigator needs snow tires.
With them, it generally doesn't need 4wd.
But without them, it won't steer or stop on the 20's!
Please don't tell me it's all about the driver. I watched the Navigator slide down a snow covered driveway one day. It was parked and had been still for several minutes before it let loose. I was standing on the porch and nobody was inside. Scary! All-seasons aren't if you get more than the occassional dusting.
I run chrome 18" F150 wheels with Blizzaks.
__________________
1997 F250HD 4wd, 460-5-speed Ext. Cab, Blue
2007 Navigator L Dark Blue Pearl
2003 Mercury Marauder, Dark Blue Pearl, Trilogy Supercharged, 13.1 @ 105
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
