Noob Here! - Ford Truck Enthusiasts Forums
Noob Here!
Old 12-27-2012, 04:47 PM
TruckEnthusiast TruckEnthusiast is offline
TruckEnthusiast is starting off with a positive reputation.
Noob Here!
Hey y'all! Noob here. I have some questions to ask y'all. I'm looking to get my first vehicle here soon and I've been looking at 92-97 F150s and F250s. I've been trying to decide if I should go with a F150 with the gas V8 in it or bump up to the F250 with the 7.3 PowerStroke. I'd use the truck to go hunting in, drive to and from school, do a little off-roading now and then, and haul my ATVs and dirtbikes with. What do you guys think is the best choice? I know the 7.3 won't go through gas like the gas truck would. But diesel is a more expensive fuel. I love love love the sound of diesels and the fact that the engines can last so long! One last thing before I go, would it be worth it to spend the extra cash to get the diesel truck instead of the gas truck? Thanks for any input that you guys have!
Old 12-27-2012, 06:26 PM
Phy's Avatar
Phy Phy is offline
Phy has a good reputation on FTE.Phy has a good reputation on FTE.
An F-150 will handle the usage you've described, and would probably cost a lot less. A diesel engine does last a lot longer, but when you do have to do maintenance on a powerstroke, it can get expensive... (a couple grand to do injectors)
Old 12-27-2012, 06:54 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT FORDF250HDXLT is offline
FORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant future
agree.the truck duties screams f150 w/ 300 inline 6.
just as legendary as all 3 generation of 7.3l's in it's own right,and just about as good on fuel,only less per gallon.cheaper parts as a rule,lower maintenance cost all the way around,and a much nicer ride.
Old 12-27-2012, 10:23 PM
deljac's Avatar
deljac deljac is offline
deljac is gaining momentum as a positive member of FTE.deljac is gaining momentum as a positive member of FTE.
Welcome to fte. I agree i would stick with the f150. Any of the gas engines will be good for what you described.
Old 12-27-2012, 11:01 PM
SCRebel's Avatar
SCRebel SCRebel is offline
SCRebel is starting off with a positive reputation.
My advice to you is to find a F150 with a 5.8, 4x4, and a supercab if you want some extra room. It will have plenty of power to tow/haul anything you will ever need it too, and retain decent mpg. About 13-14 mpg. You can squeeze more mpg out of it buy add dual exhaust, and re-gearing for city driving/towing.
I love a diesel and I plan to buy one someday. But my f150 can do all I want and more. and I even added f250HD springs. to lift my rear and so it wouldn't squat as much when towing.
Old 12-29-2012, 02:40 PM
Thank you for the warm welcome! I think I've made my choice. I think I'm going to go ahead and buy a clean and straight F150 and keep that for 5-7 years, and then, when I feel it's time to move on to a different truck, I'll move up to an F250. Thanks for the input you guys!
A decision Steven Matthew 6.0L Power Stroke Diesel 11 10-28-2014 08:49 AM
Power Issues with my truck SilentType 1999 - 2003 7.3L Power Stroke Diesel 23 07-29-2014 02:59 PM
6.0l vs 7.3 redbimmer 6.0L Power Stroke Diesel 26 02-18-2011 06:43 PM
7.3L vs 6.0 redbimmer 1999 - 2003 7.3L Power Stroke Diesel 45 02-04-2011 10:35 PM
1990 F250 Gas to Diesel? Blake F250 1987 - 1996 F150 & Larger F-Series Trucks 10 01-22-2011 10:11 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
