08 escape abs light on - Ford Truck Enthusiasts Forums
Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Old 12-27-2012, 02:41 PM
mattswabb mattswabb is offline
mattswabb is starting off with a positive reputation.
I have an 08 escape and the traction control and abs light come on. This happens every time once we start driving and hit 20mph or so. Until then the abs and traction control work fine.
I've tried a obd2 code reader that was suppose to work for the abs but no codes were stored.
Is there any common problems with this system? Is this something the dealer would need to diagnose? Or is there a way for me to check it out?
Thanks, Matt.
Old 12-28-2012, 06:20 PM
Steve_250's Avatar
Steve_250 Steve_250 is offline
Steve_250 is gaining momentum as a positive member of FTE.Steve_250 is gaining momentum as a positive member of FTE.
My wife's started doing same thing a few days ago.
Perhaps a signal from the mother ship at Ford? LOL!
I checked fuse 6 inside and fuse 9 under the hood, both were good.
Matt, did you check the fuses?
Old 12-28-2012, 07:39 PM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
Check the tone rings on each front half-shaft.
Old 12-28-2012, 08:22 PM
All the fuses are good. I work this weekend, I'll check the tone rings on Monday when I'm off. Just the fronts? Or should I check all the wheels?
Old 12-29-2012, 12:48 PM
Steve_250's Avatar
Checked the codes today and it said missing input from left front ABS sensor. Put it on a lift and found a crack in the toner ring. Its the bright spot.
I plan to replace the axle due to the ease versus messing with the ring.
Recommendations on where to buy the axle?
And which brand?
Old 12-29-2012, 02:42 PM
wptski wptski is online now
wptski is starting off with a positive reputation.
Never done one but you just replace the ring, less than $10 at any Ford dealer.
Old 12-29-2012, 03:24 PM
Steve_250's Avatar
I don't have the facilities to do it so I have to have it done. No level area...
A friend can do the axle quickly versus fussing with the ring (his request). Well worth a case of beer to let him slap the axle in. Just need to where to buy and what brand.
Matt, my friend didn't find any codes until he selected the ABS specific screen on his Snap-On reader. Granted, it was a $20,000 unit...
It came back with "No input detected" from the sensor, thats when we saw the crack.
Old 05-03-2015, 05:09 PM
Max Capacity Max Capacity is offline
Max Capacity is starting off with a positive reputation.
Thanks to this forum. GF's 2008 Escape 48,000 miles, had a ABS light on most of the time and a rattle in the front suspension.
I check the tone rings and sue enough the right front was cracked. Called NAPA, they had one there in under an hour. $55.00 for a re-man unit.
I put it in after watching a video on it. Not like I haven't done one before but nice to know what I was in for. The axle is much easier to replace then on the Honda's and Acura's my son and I have had over the years. Those two bolts on the bottom of the strut and the ABS bracket are easier then beating the lower ball joint on Civic's.
Ford Escape ABS replacement issue with VIN radioman13 Escape & Escape Hybrid 0 10-05-2016 11:22 AM
ABS and traction control lights jawdoc 2007 - 2014 Expedition & Navigator 0 01-22-2016 12:13 PM
Parking brake, ABS, and traction control lights all came on at the same time jools Escape & Escape Hybrid 3 11-14-2015 01:46 PM
Code reader/scanner question EffieTrucker Explorer, Sport Trac, Mountaineer & Aviator 4 04-23-2015 11:03 PM
2008 ford escape ABS and traction light ex0r Escape & Escape Hybrid 6 03-04-2015 09:18 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
