Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1961 - 1966 F-100 & Larger F-Series Trucks > 1961 - 1963 F100 Unibody
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
  #1 (permalink)
Old 12-26-2012, 11:03 AM
prndl prndl is offline
Garage is empty, add now
prndl is starting off with a positive reputation.
Adding Power Brakes to my '63
Is there an easy way to add a power brake master cylinder and booster to my '63. My truck originally had a standard M/C with one line out to all four wheels.
I would like to change it out to a dual M/C system with a vac booster. I still have drum brakes on all four wheels. Will this be a problem with a dual M/C setup? Will I need to install a bias system or balancer with the dual M/C?
  #2 (permalink)
Old 12-26-2012, 04:13 PM
William William is offline
William is gaining momentum as a positive member of FTE.
On line kit includes the MC, booster and splitter valve for a drum/drum system. Check out master power brakes or any of a half dozen suppliers.
__________________
William in Atlanta has retired to St. George Utah!
  #3 (permalink)
Old 12-27-2012, 01:54 PM
pburress's Avatar
pburress pburress is offline
1963 Ford F-100
pburress is starting off with a positive reputation.
I did exactly this on my '63. I bought the $300 Booster/dual master cylinder kit from Classic Performance Products and it bolted right up to the firewall and brake pedal. You will need to split front/back lines from where they converge to separate the front and back. I got everything I needed to complete it from my nearest chain parts store. You will not need a proportional valve if you are keeping it drum/drum, as I did. This is a huge improvement and pretty easy to do. While you're doing it I'd suggest you replace all four wheel cylinders and if you have the single-piston front wheel cylinders, replace these with dual-piston cylinders.
Here's a link to my brakes thread where I talk about all this and more: http://www.ford-trucks.com/forums/11...questions.html
  #4 (permalink)
Old 12-27-2012, 06:14 PM
Thank you for your help.
After all the forums i belong to you would think I would remember to use the search function
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
