stock wheels on 1993 f150 - Ford Truck Enthusiasts Forums
Old 12-25-2012, 09:50 PM
npd23 npd23 is offline
npd23 is starting off with a positive reputation.
i know that my wheels are 15x 7.5 with the 5x139 or 5x5.5 lug pattern but what is the stock back spacing?
thanks Nick
Old 12-26-2012, 10:18 AM
Conanski's Avatar
Conanski Conanski is offline
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
All stock Ford wheels have 0 offset which means the hub mounting surface is in the middle of the wheel, so the backspacing is just 1/2 of the total wheel width or 3.75" in your case.
Old 02-07-2013, 12:12 AM
RadnyB999 RadnyB999 is offline
RadnyB999 is starting off with a positive reputation.
Question Stock backspace, I'm still confused...
Quote:
Thanks for that information. But I'm still confused!
I have an offset coversion table from the back of a Wheel Pros catalog, that shows 7.5" rims at 0 offset, 4.25"
8.0" rims at 0 offset, 4.5"
10.0" 0 offset, 5.5"
These measurements all seem to be off by 1/2", or not match how you have just divided by 2.
According to this chart, 7.5" @ 3.75" is -12
I think, like many people, I want to buy aftermarket wheels, that match the factory offset. But these offset/backspace numbers seem like Greek to me!
If I am going to replace my 1990 Ford 15x8's, with aftermarket wheels and want them to fit like stock, what backspace/offset numbers should I be looking for?
Old 02-07-2013, 12:03 PM
Conanski's Avatar
The advertised wheel width is measured from the inside of the bead while the actual width is about 1" more, so a wheel that measures 7.5" outside would actually be considered a 6.5" wheel in the chart.
With these Ford trucks you don't want any more than stock backspacing or you start to get tire rub on the trailing arms and sway bar, so if you wanted to use an 8" aftermarket wheel you want it with -19 backspacing.
Old 02-07-2013, 07:35 PM
IDIDieselJohn's Avatar
IDIDieselJohn IDIDieselJohn is offline
IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.
I'm pretty sure the mag rims have abit of offset, say for example what was originally on my '94 F150, it had those hurricane steel mags, and I replaced those with regular steelies with dog dish hubcaps, and the wheels are completely inside the wheel wells instead of sticking out slightly like they did with the hurricane wheels.
Same tire size on both rims.
Old 02-09-2013, 07:23 AM
Smile I think I got it, thanks!
So in other words, my stock 15x8's, have an inner size of 7.5", so that offset would be 3.75"
Then on the chart 8" at 3.75" = -19
And depending on how different manufactures list, I'm looking for 8" with 3.75" offset or -19mm
And to change to a 10" wheel, 4,5" offset, or -25
33'x12.5 Tire on !5x10" Wheels Sandgnat 1973 - 1979 F-100 & Larger F-Series Trucks 3 11-06-2015 08:59 PM
wanted stock wheels '54 f100 16x4.5, 5on5.5 stock54f100 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 04-30-2015 05:13 AM
1992 2wd vs. 4wd Stock Wheels Justpipes 1987 - 1996 F150 & Larger F-Series Trucks 14 01-28-2011 06:21 AM
wheel backspacing??? ghostwhite 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 10-06-2010 01:59 PM
16" stock wheels, 5X5.5 es2rider WTB - Parts & other 4 03-09-2010 04:45 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
