Lock Actuator Question
I'm looking at some actuators on ebay and I am wondering if there is a difference in design from the front actuators and the rear ones? I haven't actually been into my rear doors yet so I haven't seen them. The auction is for four of them but the seller says that they won't fit the four door model. It doesn't make a whole lot of sense to me to be honest so I thought I would ask you guys. I know there are more than a few of you that have had hands on the lock actuators. The link to the ebay item is below so you can take a peek if you like. Thanks a bunch.
Mark
Lock Actuators
Mark
Lock Actuators
I cant imagine buying new actuators instead of just doing the fix on em? I after i did the fix that i found on here a few years back I have not had a problem since. If you dont know about it try a search I dont have the link but I am sure someone does and I will take a look around and see if I can find it.
Yeah I know about the fix but honestly the $40 is worth the time saved to focus on some of the other things I need to work on. I'm usually all about fixing things myself but if I can get all four for $10 a piece that just makes it seem like a whole lot of wasted time. I know that sounds lazy but I have bigger fish to fry and it's damn cold outside.
I just did one today, and the vast majority of time was spent removing and reinstalling, which you would have to do anyway.
Here's the right up I did earlier:
https://www.ford-trucks.com/forums/1...special-3.html
Keep in mind that if you buy replacements, you are going to have to replace them again a few years from now. If you fix them, it's permanent.
But to answer your question, refer to PaysonPSD above... No difference front to rear, just left to right.
Agreed, but still do not understand why you guys go through all the trouble of taking the OEM ones in and out.
You can get a set of 4 aftermarket ones for less than $20 and install them along with the factory ones. Did this on old green, and put the cheap ones in an easy to reach location so if one dies, it will be a quick swap.
