Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 12-25-2012, 03:51 PM
jestr73 jestr73 is offline
1960 Ford F-100
jestr73 is starting off with a positive reputation.
3 speed on a 289
hello all, i currently have a 60 F100 with 223 and 3 on the tree......i have a buddy who has a rebuilt 289 out of a 65 falcon with a 4 speed bell housing bolted to it...will my stock 3 speed work on the combination without any alterations.......looks like the bolt patterns are the same, and i really want to leave the 3 on the tree...
thanks in advance
  #2 (permalink)
Old 12-25-2012, 03:55 PM
85e150six4mtod 85e150six4mtod is offline
Garage is empty, add now
85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.
Your 223 and an early 289 would have the "square" bell to trans pattern.
The other concern would be input shaft length. You'll have to measure that one. The clutch disc can be changed to fit the input shaft spline if need be, and a different pilot bushing can be found or made if need be.
You might have a direct fit--that would be an excellent result!
  #3 (permalink)
Old 12-26-2012, 12:00 PM
hiball3985's Avatar
hiball3985 hiball3985 is offline
1960 Ford F-100
My Garage
hiball3985 is starting off with a positive reputation.
The truck 3 speed has a longer input shaft, also uses a larger throw out bearing and fork then the 289 bell housing.
__________________
JIM
1960 F100 Panel 223 3 spd overdrive
1966 F250 390 4 spd
1957 Ranchero 292 3 spd
  #4 (permalink)
Old 12-26-2012, 02:42 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
2013 Ford Escape
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Early 289: 1963/64 and 1965 Mustang before 8/23/1964 = 5 bell housing bolt holes.
Late 289: All 1965's from 8/23/1964, 1966/68: 6 bell housing bolt holes.
jestr73: Better verify that 289 is a 289. 1965 Falcon's came with 289's, 1964 Falcon's came with 260's. 1965 Mustang's before 8/23/1964 came with both 260 & 289's.
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
2013 Escape SE FWD 2.0L Eco-Boost.
  #5 (permalink)
Old 12-26-2012, 06:25 PM
1960 Ford F-100
thanks for the input guys....its definately a 289, can't pass up the deal so it looks like i will go the 4-speed route and put it on the floor...
  #6 (permalink)
Old 12-26-2012, 06:34 PM
hiball3985's Avatar
1960 Ford F-100
My Garage
Quote:
That opens another can of worms unfortunately. Your 60 bell housing has ears that are used as the rear mounts, the 289 won't have those, you will need to add a cross member for the trans to mount on and a new driveshaft too.
__________________
JIM
1966 F250 390 4 spd
  #7 (permalink)
Old 12-27-2012, 03:31 PM
1960 Ford F-100
understood, will need motor mounts as well as a few other things
  #8 (permalink)
Old 01-05-2013, 08:13 PM
1960 Ford F-100
ok, been thinking about this again......is there a bell housing i can use that would allow me to use the stock 3 speed on the 289 to keep the column shift....
  #9 (permalink)
Old 01-05-2013, 08:59 PM
5 bolt 289 or 6? You said in the OP that it looked like the bolt patterns were the same. Which bolt pattern? Transmission to bell?
IF you have the same (old square pattern) pattern for trans to bell, then you just need to check the input length and throwout bearing issues per the other prior post. That the motor mount issue.
SBF uses longer inputs compared to FE for example, but that does not mean it matches the older 3 gear box you have.
There is a later all synchro 3 speed that will bolt to a 289, not sure if the column shifter linkage would work.
  #10 (permalink)
Old 01-05-2013, 11:03 PM
Ford Parts Guru
2013 Ford Escape
Ford type 3.03 3 speed manual all syncromesh trans introduced in 1963 as standard equipment in F100/250's, and specific engine Ford/Merc Passenger Cars including 223 I-6 (Galaxie), 221/260/289, 352/390.
289 also introduced in 1963.
__________________
  #11 (permalink)
Old 01-06-2013, 11:47 AM
1960 Ford F-100
it is a 6 bolt 289....
i will search for that tranny.....
thanks, i appretiate the help
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
